Re: 360 block question
[Re: superchuck]
#2141386
08/26/16 04:48 PM
08/26/16 04:48 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
Do you already have cylinder heads? If you want to pushrod oil either will be fine if you are oiling through the rockers the magnum block needs modified to do that(most of them).
68 Barracuda Formula S 340
[Re: Paul_Fancsali]
#2141412
08/26/16 06:01 PM
08/26/16 06:01 PM
Posts: 2,155 Tucson, Arizona
clonestocker
Tucson, Arizona
Look for a La360 block preferably a e-58 They are as strong as block as you can find look from 1974- up to 1980 Police engine I have a 1975 E58 Block. What are the differences? thx matt
[img] [/img]
[Re: superchuck]
#2141443
08/26/16 07:17 PM
08/26/16 07:17 PM
Posts: 733 jacksonville,FLORIDA
slammedR/T
Magnum block don't need oil galley mods and pre 96 blocks have shaft oil feed into the head like an LA block.
See sig.....
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
[Re: dogdays]
#2141453
08/26/16 07:42 PM
08/26/16 07:42 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
the e-58 blocks.. also found in Lil red express trucks.. are like early 71-73 340 blocks . except the main journal diameters are for the 360 crank. and they are finished to 4.00" bore but can bored much larger because they have a thicker cyl wall than standard 360 blocks
340s were high nickel cast iron. had 318/340 mains and finish to 4.04" bore.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: superchuck]
#2141476
08/26/16 08:50 PM
08/26/16 08:50 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
so chrysler modified the casting molds in 1977ish for a few thousands LR trucks...ok
i believe the e58 just had double roller chains...windage tray and maybe a 340 camshaft...they certainly did not have the thicker bores like the early blocks...
but i dont know ...but i did stay at a motel 6 last night..
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#2141507
08/26/16 09:55 PM
08/26/16 09:55 PM
slammedR/T
but i dont know ...but i did stay at a motel 6 last night.. I stayed at a Holiday Inn so I win
[Re: A/MP]
#2141609
08/27/16 12:24 AM
08/27/16 12:24 AM
Posts: 7,506 Az
Crizila
Az
The e58 motors also had HD hydraulic rocker arms. I always come home very late. Motel 6 for me. "They leave the light on". Leaning towards a Magnum block for my next build, although I have had good lock with my E58 motors. La Quinta's for me - most have a night watchman that roams the parking lot.
Fastest 300
[Re: superchuck]
#2141645
08/27/16 01:00 AM
08/27/16 01:00 AM
cheapstreetdustr
some body ask Ted Spehar Gary Ostrich did and article or was quoted in a hot rod article. I understood they were pulled off the assembly line and build by him. but i dont know my memory isnt what it used to be...1977 was a long time ago... thats how i understood it.. frankly i could give a [censored] never owned one of them..
ive never stayed at a holiday in... i only stay at the Marriot's Rits Carlton..
[Re: superchuck]
#2141694
08/27/16 01:58 AM
08/27/16 01:58 AM
cheapstreetdustr
i have no problem admitting i was wrong. and i very well may be. i have no dog in the fight. i also realize how rumors are spread. i wouldnt want to repeat 3rd party info that was wrong..which it appears i may have done. ill stand corrected.
cheers
how you doin Monte..? havent seen you in a long time. but i see you are keeping busy. glad to hear from you.
sorry i hi jacked your thread Superchuck
[Re: superchuck]
#2141762
08/27/16 09:46 AM
08/27/16 09:46 AM
Bad340fish
Tulsa OK
I believe you would have to drill the block for oiling, not sure how easy that is. I don't believe the deck height is any different than a regular small block.
