Vacuum source for distributor? #2140758
08/25/16 07:31 PM
08/25/16 07:31 PM
n.e. pa.
65rbdodge Offline OP
n.e. pa.
I'm installing the kit from speedway motors to put 3x2 9 super 7 carbs on my motor. There is nowhere to connect my distributor to, what are my options?
Re: Vacuum source for distributor? [Re: 65rbdodge] #2140847
08/25/16 09:37 PM
08/25/16 09:37 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Don't be the exception.
Re: Vacuum source for distributor? [Re: Supercuda] #2141327
08/26/16 03:16 PM
08/26/16 03:16 PM
dogdays Offline
dogdays  Offline
From Speedway Motors catalog:
5.There are no provisions for a vacuum advance line. Ford & Mercury engines 1949-1953 using stock distributors will need an alternative place to connect the vacuum line.
The real Stromburg folks just spent a mint to get the carb back into production, that one does have ported vacuum. So, why would they want to give tech advice to a clone?
I also found this: "The ported vacuum 97 base is also available separately if you already have a suitable Stromberg 97. See part No. 9514-VP, under Service & Restoration parts." Factory price is $149.
R.
Re: Vacuum source for distributor? [Re: 65rbdodge] #2141477
08/26/16 08:53 PM
08/26/16 08:53 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Because they had info online on how to add ported vacuum to a 97 before they started making them that way.
Re: Vacuum source for distributor? [Re: Supercuda] #2141614
08/27/16 12:27 AM
08/27/16 12:27 AM
Az
Crizila Offline
Crizila  Offline
Az
or you could just tap in to the intake manifold and run manifold vacuum.
Fastest 300
Re: Vacuum source for distributor? [Re: Crizila] #2141683
08/27/16 01:39 AM
08/27/16 01:39 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Not without issues.
Re: Vacuum source for distributor? [Re: Crizila] #2151683
09/10/16 03:45 PM
09/10/16 03:45 PM
hooziewhatsit Offline
Yep, I just did that in my truck to get more timing at idle. So far it's working great.
You need to make sure that the vacuum advance kicks in below whatever vacuum you have idling in gear (if automatic), and make sure that your total timing is good.
I can go into more detail if there's interest.
Re: Vacuum source for distributor? [Re: hooziewhatsit] #2152154
09/11/16 09:18 AM
09/11/16 09:18 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
OK, so what am I missing here? If you have all the vacuum advance "in" at an idle, when the motor's vacuum is at its highest point, when you step on the throttle, and the vacuum drops, won't you get a decrease in the ignition timing at a point the timing should be advancing?
A ported vacuum has little vacuum at idle, and as the throttle opens, the vacuum increases, which causes the vacuum advance to advance the ignition timing, as it was intended to do.
Have things changed since I was in auto classes in the early 70s? Gene
Re: Vacuum source for distributor? [Re: poorboy] #2152252
09/11/16 12:08 PM
09/11/16 12:08 PM
Az
Crizila Offline
Crizila  Offline
Az
Without making this too complicated, the only real difference between ported and manifold vacuum is at idle - and you know what that is. When you mash on the throttle, all vacuum pretty much goes away and you are just running on the mechanical advance built in to the distributor. At cruise, you have about the same vacuum advance ( ported or manifold ) added to the mechanical advance. Your engine is under minimal load at cruise and the additional advance of both mechanical and vacuum will make best fuel mileage. Total for both at cruise should be in the 50 degree range ( about 35 for mechanical and 15 for vacuum ). These are "approximate" #'s. Altitude, DA, and many other engine factors come in to play here. beer
Fastest 300
Re: Vacuum source for distributor? [Re: 65rbdodge] #2156671
09/18/16 09:13 AM
09/18/16 09:13 AM
n.e. pa.
n.e. pa.
Ok so I drilled out one of the plugs above the idle mixture screws and put a fitting in with some JB weld. It works perfect.
