Re: Header temp
[Re: emarine01]
#214123
02/04/09 04:57 PM
02/04/09 04:57 PM
Posts: 146 michigan
tonycpe
michigan
385 to 395 degrees if I remember corectly
QC coatings coated em pretty nice.
Old Fogey Racing Ltd.
Re: Header temp
[Re: emarine01]
#214125
02/04/09 05:19 PM
02/04/09 05:19 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
im usually around 500 without coating
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: Header temp
[Re: emarine01]
#214126
02/04/09 06:54 PM
02/04/09 06:54 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
Hey what kind of header temps with a infra red gun are you guys seeing , engine warm @ idle , hottest point on header?
i would not think a gun could read a fully warmed engine exhaust.i just have an EGT that reads 1320+/- after a run aqt idle.i think a gun goes to 900F.
Re: Header temp
[Re: blownzoom440]
#214127
02/04/09 07:17 PM
02/04/09 07:17 PM
Posts: 3,695 nc
emarine01
nc
My gun reads to 999 , egt would be lots higher than infra red ,egt is in the path of the exhaust , infra red is outside jacket , egt is the way to go for real #s but for the rest of us infra red will have to do
Re: Header temp
[Re: Cab_Burge]
#214129
02/05/09 05:52 AM
02/05/09 05:52 AM
blownzoom440
ELYRIA,OH
EGT at idle versus header temps at idle below 1100 RPM will be a bunch lower than 1000 F, or they should be. Running the motor at or above 1200 RPM will make both temps go up
that must be my problem.i have high idle. emarine01are you thinking of wrapping the headers or thinking of other things?how about some pictures it is winter.
Re: Header temp
[Re: emarine01]
#214132
02/05/09 07:26 PM
02/05/09 07:26 PM
Posts: 1,532 off the grid
340B5
off the grid
830 to 860 here w/uncoated headers,then go's over 1000 off idle and above.
Yeah, it's got a smallblock.
