Re: 3spd trans ID
[Re: 71GTX471]
#2140884
08/25/16 10:08 PM
08/25/16 10:08 PM
Posts: 21,084 Niles , Ohio
therocks
Niles , Ohio
Ive had one in the garage for at least 15 years with shifter.pretty much no value.Mine IIRC was from like a 70 or so V8.there are 2 3 speeds.Mine is the one for V8s.Rocky
Chrysler Firepower
Re: 3spd trans ID
[Re: 71GTX471]
#2140946
08/25/16 10:54 PM
08/25/16 10:54 PM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
TA I didn't think so Ill have him ck.again,Rocks I thought there was 2 types how can u tell?
Tnx Mike Actually I think Mopar used at least 3 types in the 60's and 70's. The 6 cylinder ones are very light weight and physically much smaller than the V8 ones. I have several of the A745 trannies for my 65 Fury. Small block and big Block are different in 65 as the 1st gear ratios are different. Much easier to find the small block ones. Most of not all of the A745s I looked at had destroyed gears because 1st is not synchronized in these trannies.
Re: 3spd trans ID
[Re: 71GTX471]
#2140949
08/25/16 10:55 PM
08/25/16 10:55 PM
therocks
Niles , Ohio
I posted the pad #s here and was told what it was.Tried to get 50 bucks for it and no bites.I have a 69 I think 4 speed also.It came supposedly from a RR.I still have to post numbers to see if the car is still alive.Rocky
Chrysler Firepower
Re: 3spd trans ID
[Re: pushbutton]
#2141048
08/26/16 12:30 AM
08/26/16 12:30 AM
Posts: 3,464 Back in NJ....
EWJ
Back in NJ....
Mike- New Process three speeds pre-1970 are a non synchro first gear. 1970-up are synchro. The odd ball "rare" New Process three speed is the one that came behind a 383/4bl. It has larger bearings and a close ratio gear set, which sets it apart from others that came behind a /6 or 318 car. As most buyers paid the few extra $$ for the 4 speed, and for the few 3 speed cars-many were swapped out for 4 speeds and the 3 speed discarded- makes this trans not very common (big bearing/close ratio one). We have one of these transmissions: came out of a 1970 FC7 Challenger which used to be a pace car at the Flemington NJ speedway back in the day. Car was cut up in 1982 or so, and we picked it up back then. Used it in a 1970 NYer and my 1967 Newport over the years.
How to ID one will be the bearing retainer and the first gear ratio. The bearing retainer will be the same as. 23 spline 4 speed. Cannot recall the first gear ratio, but it will be tall (low numerically), something like 2.90 (vs 3 and change in a wide ratio one)
Ed EastCoast Land Yacht Assoc. 1967 Newport Conv: 440/4 speed 1969 GTX: 440/4 speed, TX9/TX9, A34, N96 1970 Super Bee: 383/4 speed, B5/B7 1970 Coronet RT: 440/4 speed, A34, N96 1970 Coronet RT: 440/auto, A36, N96 1970 Road Runner convertible: 383/4 speed TX9/D6XW 1970 GTX: 440+6/727, A32, N96 2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed "The early bird may get the worm, but the 2nd mouse gets the cheese".
