What are my auto trans options other than a 727?
#2140548
08/25/16 01:23 PM
08/25/16 01:23 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
What can go behind a 440 based big block for street strip, 650hp might spray it not sure. I need to buy a custom converter now so it is the time to think about a trans also. I was thinking t 400?
Have a great day Iowan
"obsolete is neat"
Re: What are my auto trans options other than a 727?
[Re: Iowan]
#2140569
08/25/16 01:48 PM
08/25/16 01:48 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
If you have NOTHING hard to not go with a Turbo 400.
Look at it realistically. A shifter is a shifter, a converter a converter, valve body, etc so those parts are a wash on cost. A turbo 400 core for basic parts will likely be cheaper than the 727. You buy a Reid or ATI case with a Mopar bell, no adapters needed. Nor will you need to buy shields or blankets to cover that 40 year old stock case.
Now, if you have a shop full of 727 parts, it's hard the justify the 400 at your power level, but if not, 400 is the easy choice. Better trans, better converter selection, better parts selection
[Re: Iowan]
#2140599
08/25/16 02:19 PM
08/25/16 02:19 PM
Iowan
Lost in Time
I'm just asking, I've been out of the car for twenty years and a lot has changed. I'm not sure if my 727 is good after sitting all that time, not sure how good it was when it was parked. It's going in an F body.
I like the no trans shield and I'm looking for reliability, this is a mid to low 10 second street car that will get driven.
"obsolete is neat"
[Re: justinp61]
#2140604
08/25/16 02:25 PM
08/25/16 02:25 PM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
Monty will the 400 go in the same space as a 727, an A body for instance? The 400 has a long maincase extending rearward, so I think you are going to be at least cutting the torsion bar crossmember out of the trans hump.
[Re: JohnRR]
#2140605
08/25/16 02:26 PM
08/25/16 02:26 PM
Iowan
Lost in Time
Monty will the 400 go in the same space as a 727, an A body for instance? The 400 has a long maincase extending rearward, so I think you are going to be at least cutting the torsion bar crossmember out of the trans hump. Not a problem on F body.
"obsolete is neat"
[Re: Iowan]
#2140607
08/25/16 02:28 PM
08/25/16 02:28 PM
Monte_Smith
North Alabama
n20mstr has a 400 in an A-body. He would be the one to answer about the fit
While I haven't sat the two side by side, both the 400 and 727 would be required to have virtually the same main case length and dimensions, because both are 3 speeds and you need the room you need to get the parts in it. The 400 has a lot shorter output shaft and tail housing. I THINK it would be a no problem fit, but don't know that for sure
[Re: Iowan]
#2140619
08/25/16 02:57 PM
08/25/16 02:57 PM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I don't know if a TH400 will fit in the stock transmission tunnel. Might have to do some work there. You would probably have to fabricate/redo a transmission crossmember. You would have to redo your driveshaft or have another one made. Hopefully it wouldn't hit the headers. Doubt the speedo would work if you need that. The main thing a TH400 gives you is the ability to buy a heavy case. Wish the 727 had that.
2011 Drag Pak Challenger
[Re: JohnRR]
#2140661
08/25/16 04:07 PM
08/25/16 04:07 PM
Posts: 25,819 Rio Linda, CA
John_Kunkel
Rio Linda, CA
For comparison, a 727 case is about 16".
[Re: Monte_Smith]
#2140696
08/25/16 05:21 PM
08/25/16 05:21 PM
Posts: 760 Southington Ct.
turbobitt
Southington Ct.
The 400 will have an intermediate clutch pack and center support that adds extra length. I'm guessing that the bell housing would be deeper since there is a lot of talk about GM converter cores being thicker and/or better giving them better options. AG.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
[Re: Iowan]
#2140770
08/25/16 07:53 PM
08/25/16 07:53 PM
Posts: 4,682 On the parachute mount
n20mstr
T400 is a little smaller but the case is longer, 727 is more shaped like a funnel. That said the original "frame" rail / t bar crossmemeber will need to be trimmed where is passes over the trans. I cut mine back about 1/2" and then boxed it back in with 16ga sheetmetal. Then just run a straight crosmember across between frame connecters and your done.
....BAD A$$ STREET CAR.....
[Re: Iowan]
#2140828
08/25/16 09:15 PM
08/25/16 09:15 PM
Posts: 7,506 Az
Crizila
Az
Since you already have the 727, get it rebuilt to handle that HP. Pic the convertor you want, and run it with a blanket.
Fastest 300
[Re: Crizila]
#2140929
08/25/16 10:42 PM
08/25/16 10:42 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
CSI sheild is a better choice. The blanket hangs in the shifter cable.
I have no idea about a stock 400 case. But the Reids I sell are much heavier than 727. Much heavier than powerglide too.
