Grease... what types for which parts?
#2126604
08/06/16 04:22 PM
08/06/16 04:22 PM
Posts: 8,131 New Mexico
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
I'm trying to research which type grease to use for my Torsion bar sockets? It appeared the factory used a heavy (peanut butter) type lube if my low mile car had it's original lube as it appeared. Chrysler called for "Multi=mileage Lubricant, Part Number 2525035 originally. On my Disc brake wheel bearings I used Mopar wheel bearing grease. Click here LINK I' would think that a moly grease would be best for the ball joint sockets and tie rod ends? This is the new Mopar multi mileage grease apparently good for ball joints but it say's it's barium based: click here LINK What have you had success with long term? Do some greases in certain components break down the closer to header heat they might be? Thanks
Re: Grease... what types for which parts?
[Re: UCUDANT]
#2126870
08/07/16 12:48 AM
08/07/16 12:48 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I've been using Mobil 1 red in everything. Have yet to see a reason to change yet. Redline would be my next step up.
Mopar to the bone!!!
[Re: UCUDANT]
#2127140
08/07/16 02:26 PM
08/07/16 02:26 PM
Posts: 22,696 Bitopia
jcc
Bitopia
On TB sockets, other then a daily driven car, my feeling the main goal is corrosion prevention, I'm not convinced any wear would cause a problem in less then 100K? miles, and if it did, no real downside performance wise. That being said, maybe a light coat of synthetic grease, and FWIW, I don't use the TB boots anymore, driving on dirt roads though, with grease might be messy I suspect. On a similar line of thought nobody(?) greases the ball end of the TB adjuster screw. On some other greasable/lube points, I might lean towards the frequency as a better plan then over great concern about the type of grease.
[Re: ahy]
#2140546
08/25/16 01:16 PM
08/25/16 01:16 PM
jcc
Bitopia
" the T bars will creak and groan as they work." Actually, if the chassis was perfectly stiff, I don't believe there would be any movement in the last 1" to generate any noise from a TB end mount hex. And TB's are always preloaded to the minimum of the chassis weight (ie no slack take up), and I would think if a TB became completely unloaded/relaxed during driving, any sound generated would be severely masked by other road/tire noises. Since everyone's chassis stiffness is different, we all might have different outcomes. I believe a TB does shorten as it is twisted a small amount, not sure by how much or how dependent that shortening is on TB dia. Need to do some homework.
