Keeping front end low downtrack
#2140045
08/24/16 05:28 PM
08/24/16 05:28 PM
Posts: 69 norcal
JLaSalle
norcal
So what is the preferred method for keeping the front end low going downtrack on a car that likes front end travel on the starting line?I have a low 10 sec. b-body with stock front end,.840 bars,and qa1 singles.Has a glide,so the slr isnt bad.Have limiters with about 3" of travel and this last weekend we had a nasty up and down headwind that threw me for a loop.Got me to thinking that maybe it needs to be lower and out of the wind more.Limiting front travel is what Im thinking but I dont want to sacrifice the starting line.Thoughts?
1967 Coronet R/T 9.83 134mph. 470 cid st.6 heads 10x pro et track champion
Re: Keeping front end low downtrack
[Re: JLaSalle]
#2140067
08/24/16 06:02 PM
08/24/16 06:02 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Put a front spoiler (chin spoiler) on it.. as speed picks up it will have more effect and still gives you your lift at the line
[Re: JLaSalle]
#2140084
08/24/16 06:45 PM
08/24/16 06:45 PM
Posts: 22,696 Bitopia
jcc
Bitopia
You can also experiment with taping/blocking any part of the grille as long as you can keep temps under control, best done with a front spoiler. Also keep in mind, any changes with airflow at the front, effects almost every surface that follows, hence the earlier comment of maybe also needing a rear spoiler/wing, but added control is likely your result/goal.
[Re: JLaSalle]
#2140234
08/24/16 10:31 PM
08/24/16 10:31 PM
Posts: 10,021 MN
JERICOGTX
MN
Buy better shocks and limit the front end travel. Install a bracket on the frame rail and install a bolt and jam nut to limit the upper A arms.
69 GTX
68 Road Runner
[Re: MR_P_BODY]
#2140349
08/25/16 12:17 AM
08/25/16 12:17 AM
Posts: 69 norcal
JLaSalle
norcal
Put a front spoiler (chin spoiler) on it.. as speed picks up it will have more effect and still gives you your lift at the line I like the idea Mr.P,didn't think of that.Something flat black and mostly out of sight sounds interesting
[Re: Mopar_Rich]
#2140355
08/25/16 12:22 AM
08/25/16 12:22 AM
Posts: 69 norcal
JLaSalle
norcal
I think you need to loan me your car for a few months so I can work it out!😎 LOL. Rich there's not many people I'd have drive my car,but you'd be on that list.I see you've been playing musical cars lately,lol.
