Overtired or Not? #214012
02/04/09 02:59 PM
02/04/09 02:59 PM
Bakersfield, CA
MarkKirby Offline OP
Bakersfield, CA
Ok, here's my dilemma.
I have run a 14.0 x 32 for several years since we back halved the car. It is now a 4 link at 3200lbs. My question is whether or not there is something worthwhile to gain by stepping down on tire size. I rarely have tire spin but one wouldn't expect it with this much tire and this little power. Should I step down to perhaps a 29.5 or some kind of 10.5 combo? What do y'all think?
Current combo:
416SB
575hp, 540lbs tq
904 w/ 2.74 low gear
5:13 Dana
4 link at 3200lbs with me in it
Strange double adjustable shocks(rear)
8" 5500 converter
Launch at 4800, shift at 6500, traps at 6900
Current 60' = 1.39-1.40, ET = 10.49 at 123mph
Mark & Nancy Kirby 1971 Plymouth Duster The Grape Ape 10.20 @129mph 1.32 60'
Re: Overtired or Not? [Re: MarkKirby] #214013
02/04/09 03:31 PM
02/04/09 03:31 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
The car would likely work better and run faster, with a 33x10.5 M/T tire.
Monte
Re: Overtired or Not? [Re: Monte_Smith] #214014
02/04/09 04:09 PM
02/04/09 04:09 PM
Q
Quicktree Offline
Quicktree  Offline
Q
if you went to a smaller tire you would have to take a lot of gear out of that thing. I am in the same boat with a large tire low hp deal. but I am not real worried about the ET loss if I can make it hook.
Re: Overtired or Not? [Re: Quicktree] #214015
02/04/09 04:49 PM
02/04/09 04:49 PM
Sheboygan, Wi.
S/SSJOHN Offline
S/SSJOHN  Offline
Sheboygan, Wi.
In regard to your question ,a young guy that hangs around my shop and helps me on my race car, built a 66 Dodge Dart 2dr Post Bracket car! This car weighs 3400 # w/him in car has a 416 S/b with a 800, d/p Edelbrock heads flat tappet cam, around 12.0 comp, and no spray! Trans is a 904 w/2.75 first and a 4.30 rear, w/11.5X28.5 Slick, using Cal-Tracs and their springs and shocks! This is an all steel except for a glass hood w/rear open scoop! I think thats about it for specs, the car turns steady times of 10.15-10.20 @ 131.00 mph in average midwest air! At Union Grove Wi. 60 FTs at1.37. It flat as hauls and there is nothing real trick in it. John Lang
Re: Overtired or Not? [Re: S/SSJOHN] #214016
02/04/09 04:58 PM
02/04/09 04:58 PM
Sheboygan, Wi.
S/SSJOHN Offline
S/SSJOHN  Offline
Sheboygan, Wi.
I forgot to answer your question, yes your over tired! Why pull more weight than you need! Also the above Dart we don't know the HP cause it's never been on a dyno, the convertor is a Dynamic, No trans brake yet, he leaves on a 2 step at 2500, shifts (air) at 6500 clears lights at 7200! By the way that also is a cast crank! The convertor flashes at 4500! Later... John Lang
Re: Overtired or Not? [Re: S/SSJOHN] #214017
02/04/09 05:04 PM
02/04/09 05:04 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
If you are just bracket racing then stay with the big tires. Do you care what ET it runs?????/
If you care or are trying to pick it up just for the heckuva it then I agree with Monte
Re: Overtired or Not? [Re: S/SSJOHN] #214018
02/04/09 05:07 PM
02/04/09 05:07 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I would think the car will be more consistent with the bigger tire; less tire may ET or MPH better but can make the car more track-sensitive.
My Duster's pretty similar, except 358" & approx 630HP, 5.38 gear, 13x31s, 5800 Dynamic, modified SS leafs, and seems sensitive to track prep. Might go to the Caltrac setup if I don't restore it to its original (period) SS/IA configuration.
Re: Overtired or Not? [Re: topside] #214019
02/04/09 06:48 PM
02/04/09 06:48 PM
Bakersfield, CA
Bakersfield, CA
All these answers make sense. This is also an old SS/IA car. I was pretty sure we would pickup ET with a smaller tire but since we run at lots of different tracks and lots of different weather conditions it seems to make sense to stay with the bigger tire for this protection. I really don't need to drop tenths off the ET because I like running at the top of Super Pro and knocking off 170mph dragsters all day. However, one always wants to know what the optimum configuration might be for any combo.
That 2dr post car is really kicking it for what it has in it. Way to go.
Re: Overtired or Not? [Re: MarkKirby] #214020
02/04/09 08:23 PM
02/04/09 08:23 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
It may actually be MORE consistent with a smaller tire. Some lowered powered cars with big tires are not always consistent, because the car does not have the power to actually "work" the chassis to stick the big tire.
Monte
Post deleted by Defbob [Re: Monte_Smith] #214021
02/04/09 08:40 PM
02/04/09 08:40 PM
Re: Overtired or Not? [Re: Monte_Smith] #214022
02/04/09 08:41 PM
02/04/09 08:41 PM
Wisconsin
Garceau Offline
Garceau  Offline
Wisconsin
True to a point Monte - but he has a 4 link, he has and can put in the mechanical advantage of the proper IC and make the car "act" many different ways.
I have seen issues with over tires on LB cars and Spring cars. But to be honest - bracket racing = over tire, under power, loose converter and your winning rounds.
Re: Overtired or Not? #214023
02/04/09 09:37 PM
02/04/09 09:37 PM
Monte
last year Monte suggested I do the same. the results were quick to prove him right. My 60' dopped from 1.26 to 1.22 and picked up almost a tenth in the 1/4
what are you talking about. i talked you into those tires!
where do you think you got them from?
Re: Overtired or Not? #214024
02/04/09 09:47 PM
02/04/09 09:47 PM
Bakersfield, CA
Bakersfield, CA
The truth is...on many days, when the weather cooperates, the car is dead on consistent. At our very last race we made 7 passes in a row within .007 and won the event. Obviously, there are days when we are not as "on" but it is usually a factor of DA or driver brain farts. As far as tire is concerned I don't think we could get more consistent. The car almost never reacts to air pressure adjustments. I have run between 9-13lbs without varying .01 on the 60'. I typically run the shocks at two clicks from full extension and midway on the rebound. No down track issues with this setting and the extension is mostly adjusted to control wheelstands. At this setting, on our first pass at the Thanksgiving event at Las Vegas the first launch was pretty exciting. I was able to watch an F-15 land at Nellis AFB between launch and the 1-2 shift.
I haven't really started to experiment with front shocks yet but that's kind of in the plan for this year. Still running non-adjustable worn out station wagon shocks.
Re: Overtired or Not? [Re: S/SSJOHN] #214025
02/04/09 10:47 PM
02/04/09 10:47 PM
Way North Illinois
JandJ_Racing Offline
Way North Illinois
I think I know that guy just cant remember his name, I know he know the Sheboygen Genskis And yes his car runs well, I think he told me that the bottom end had a bunch of years on it.
Re: Overtired or Not? [Re: Monte_Smith] #214026
02/05/09 10:52 AM
02/05/09 10:52 AM
Swamps of South Jersey.
W
wildcargo Offline
wildcargo  Offline
W
Monte
Is this a 33x10.5 or a 10.5W and what rim 14" ?
Bud www.wildcar-go.itgo.com
64 DODGE
60' 1.433,
1/8 6.38 at 107.4,
1/4 10.08 at 132.02
foot brake, leaf springs
Re: Overtired or Not? [Re: MarkKirby] #214027
02/05/09 11:15 AM
02/05/09 11:15 AM
off the grid
340B5 Offline
340B5  Offline
off the grid
Hello to all. I'm a new member, been following Moparts every day for about 2 months. I say keep the bigguns, enjoy the traction and knowlege that even if track prep isn't that good you'll be able to stick it! Good looking Duster; added it to my pic collection.
Yeah, it's got a smallblock.
Re: Overtired or Not? [Re: 340B5] #214028
02/05/09 11:24 AM
02/05/09 11:24 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Welcome to Moparts.
Big tires don't guarantee traction. I ran 14" x 32" Goodyears
on a 340 powered 2830 lb. car and it took me awhile to get it
to hook. Big tires were no cure-all for poor track prep either.
Re: Overtired or Not? [Re: S/ST 3040] #214029
02/05/09 12:01 PM
02/05/09 12:01 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
I stand partially corrected. Big tires are no cure all. Laws of physics would state it's all about PSI to the pavement. I personally wouldn't spend $1000 for a couple mph, or a couple hundredths 60'.
Re: Overtired or Not? [Re: 340B5] #214030
02/05/09 12:16 PM
02/05/09 12:16 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Seems to me you are answering your own original post with your replies here.
Re: Overtired or Not? [Re: 340B5] #214031
02/05/09 12:21 PM
02/05/09 12:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Welcome to the jungle
