1971 Challenger Engine Install, Hood on??
#2140079
08/24/16 06:25 PM
08/24/16 06:25 PM
Posts: 250 Cent, OH
Mopar.70
Cent, OH
Pre-planning the 440 engine install in my Challenger this winter. Curious if anyone has installed a 440 in one with the hood on? Motor only, no trans. . .or does the hood NEED to come off?
Re: 1971 Challenger Engine Install, Hood on??
[Re: Mopar.70]
#2140137
08/24/16 08:04 PM
08/24/16 08:04 PM
Posts: 2,735 541 slobovia
A990
541 slobovia
Never done an E body myself, But A bodies several times You'll need a load leveler and time. Also you might have to use something to get the hood up all the way. There's usually some sloppininess that lets it droop enough to interfere. Good luck! Oh yeah, be sure you can roll your hoist. Gravel or dirt makes the job tougher, if not impossible.
[Re: Mopar.70]
#2140626
08/25/16 03:07 PM
08/25/16 03:07 PM
Posts: 5,139 East Aurora (Buffalo) NY
RoadRunner
Factory installed engine and k frame from bottom. Hood was on and painted already. So yes it can be done. But not from the top. I don't think there is enough clearance to get engine dropped into position with hood on. You need some way of hanging the engine from engine crane (cherry picker). That alone will add a few inches.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
