Re: 904 low gear set, how to tell??
[Re: DemonDust]
#2139234
08/23/16 11:39 AM
08/23/16 11:39 AM
Posts: 2,155 Tucson, Arizona
clonestocker
Tucson, Arizona
So you weld both sides of the planetary on the gear set? Or just the factory welded side? I've had them come out with the factory back side weld broke. I can't remember if I redid the factory side but the fillet was tigged. You also need to clearance the carrier sometimes at the bushing because it will interfere with the tigged fillet weld.
[img] [/img]
[Re: scottb]
#2139752
08/24/16 07:05 AM
08/24/16 07:05 AM
Posts: 384 Australia
Mcode69
Australia
Not trying to high jack your post but does any sell or make the wide 2 inch a band They are available but you usually need to supply a 2" core, they are pretty much dried up.
