Re: 904 low gear set, how to tell?? [Re: DemonDust] #2139234
08/23/16 11:39 AM
08/23/16 11:39 AM
Tucson, Arizona
clonestocker Offline
Tucson, Arizona
Originally Posted By R5P7Duster
So you weld both sides of the planetary on the gear set? Or just the factory welded side?
I've had them come out with the factory back side weld broke. I can't remember if I redid the factory side but the fillet was tigged. You also need to clearance the carrier sometimes at the bushing because it will interfere with the tigged fillet weld.
[img] [/img]
Re: 904 low gear set, how to tell?? [Re: DemonDust] #2139356
08/23/16 04:01 PM
08/23/16 04:01 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Not trying to high jack your post but does any sell or make the wide 2 inch a band
Re: 904 low gear set, how to tell?? [Re: DemonDust] #2139505
08/23/16 08:15 PM
08/23/16 08:15 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Since we're on this 904 subject, is there some book or article on building this trans for racing? I have tons of info on the 727 but this will be my first 904, race only by the way.
Re: 904 low gear set, how to tell?? [Re: scottb] #2139752
08/24/16 07:05 AM
08/24/16 07:05 AM
Australia
Mcode69 Offline
Mcode69  Offline
Australia
They are available but you usually need to supply a 2" core, they are pretty much dried up.
Re: 904 low gear set, how to tell?? [Re: DemonDust] #2139770
08/24/16 08:47 AM
08/24/16 08:47 AM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
I got mine from A&A. But as M code stated, I believe I had to send the old one in.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: 904 low gear set, how to tell?? [Re: DemonDust] #2140068
08/24/16 06:08 PM
08/24/16 06:08 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I got 2 from transact a couple yrs ago. No core.
