Re: powerglide options
[Re: sergio]
#2139845
08/24/16 12:22 PM
08/24/16 12:22 PM
Triple Threat
Renton Washington
Hughes is the big name company that's closest to you, aside from them the possibilities are endless; BTE, FTI, ATI, Transmission Specialties, A1.....
I believe BTE uses its own case design, most of them other brands use a Reid case.
All of them can build good stuff, and you'll probably find someone who has horror stories about each. I recommend picking up the phone, giving them a call and talking it through with them.
[Re: sergio]
#2139873
08/24/16 01:06 PM
08/24/16 01:06 PM
Posts: 11,676 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Depends on if the car is set up with an adapter plate to allow for use of a Chevy pattern case or do you need to use one of the aftermarket bellhousing type of units. I've used JW stuff in the past, but if I were starting from scratch, I would go with the ATI case and appropriate bellhousing. Get everything from one source to avoid fitment issues.
Chevy pattern case? Probably a Reid or if you are buying a complete trans, Hughes is close to you and they do a lot of pro tree stuff..
