Do you guys like the fast ratio P/S steering on your TA Challenger or AAR Cuda? I just don't like the lack of road feel on my AAR. It almost feels unstable at higher speeds also. Could part of this be due to my front end alignment?
IMO, two separate concerns.
Road feel is typical Chrysler over assist. You can change the pump to a modern unit or reduce the output of the stock pump to improve this.
High speed instability can be a result of high speed combined with a fast ratio, but usually not at highway speeds, but rather is the result of the alignment. Not enough caster will cause this although that is assuming tire air pressure, shocks, springs, etc are all set up properly and performing their jobs correctly. Steering wheel diameter also plays into this. But, stepping up positive caster will help.
While you are improving positive caster, also add some negative camber too. Radials, if in use, can use much more aggressive alignment specs than a bias ply, which is what the original alignment specs were designed for.
If after those changes, you still feel it is too unstable, then you could consider dumping the fast ratio arms for standard arms to slow down the reaction from your input.
