70 Roadrunner Turn Signal Problem #2138766
08/22/16 06:38 PM
08/22/16 06:38 PM
Port Reading, NJ
roadrunner7070 Offline OP
Port Reading, NJ
Hey guys. Having an issue with the turn signals. When I move the lever to signal left or right the signal will come on and blink for three or four times. Then stop. It's been so long since I put the car back together I can't remember it there is a part that controls the signals like the flasher unit. The emergency flashers work fine. Any help?
Re: 70 Roadrunner Turn Signal Problem [Re: roadrunner7070] #2138774
08/22/16 06:50 PM
08/22/16 06:50 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Yes there is flasher just for the turn signals. Make sure you check all the bulbs. Also, all your grounds ! . . . if you had painted the car, then need to make sure you scrape through paint to good ground.
Re: 70 Roadrunner Turn Signal Problem [Re: a12rag] #2138780
08/22/16 06:57 PM
08/22/16 06:57 PM
Port Reading, NJ
Port Reading, NJ
OK. So where is the flasher located? I just see the emergency flasher unit. Everything has worked fine for the past 10 years.
Re: 70 Roadrunner Turn Signal Problem [Re: roadrunner7070] #2138788
08/22/16 07:06 PM
08/22/16 07:06 PM
a12rag Offline
a12rag  Offline
If I recall correctly, I think it is up under the dash on drivers side, might be clipped onto the lower part of metal dash panel, or the steering column support . . . according to wiring diagram from FSM, it is up against the drivers side of the ash tray . . .
Re: 70 Roadrunner Turn Signal Problem [Re: roadrunner7070] #2138824
08/22/16 07:41 PM
08/22/16 07:41 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Easiest way to find it is stick your head under the dash and turn the signals on. Listen for the click.
Re: 70 Roadrunner Turn Signal Problem [Re: roadrunner7070] #2138826
08/22/16 07:43 PM
08/22/16 07:43 PM
Chicagoland 'Burbs
SlickRS23 Offline
SlickRS23  Offline
Chicagoland 'Burbs
Mine would flash a couple of times then go really slow and then stop.
I went to napa and they had a "more modern" one there. Can't remember what the diff was but now it works perfect.
It did not have a bracket on it to screw it to the bottom of the dash like the original, so I left the original screwed to the dash and layed the new one next to it.
Re: 70 Roadrunner Turn Signal Problem [Re: roadrunner7070] #2138868
08/22/16 08:32 PM
08/22/16 08:32 PM
a12rag Offline
a12rag  Offline
Old original ones were a bi-metalic type, similar to the voltage regulator for the instrument panel. New style are electronic ...ie.more modern
Re: 70 Roadrunner Turn Signal Problem [Re: stumpy] #2138928
08/22/16 09:52 PM
08/22/16 09:52 PM
Port Reading, NJ
Port Reading, NJ
I did. It sounds like it's coming from directly in back of the gauge cluster.
Re: 70 Roadrunner Turn Signal Problem [Re: a12rag] #2138931
08/22/16 09:55 PM
08/22/16 09:55 PM
Port Reading, NJ
Port Reading, NJ
That is the emergency flasher next to the drivers side ash tray.
Re: 70 Roadrunner Turn Signal Problem [Re: a12rag] #2138932
08/22/16 09:56 PM
08/22/16 09:56 PM
Port Reading, NJ
Port Reading, NJ
That is the emergency flasher unit next to the drivers side ash tray.
Re: 70 Roadrunner Turn Signal Problem [Re: roadrunner7070] #2138946
08/22/16 10:20 PM
08/22/16 10:20 PM
if your E flasher can is working, swap it for the TS one & if this straightens out the TS lights
Re: 70 Roadrunner Turn Signal Problem [Re: RapidRobert] #2138956
08/22/16 10:25 PM
08/22/16 10:25 PM
Port Reading, NJ
Port Reading, NJ
I cant find the turn signal flasher!!!!!!!!!!!!!!
Re: 70 Roadrunner Turn Signal Problem [Re: roadrunner7070] #2139005
08/22/16 11:44 PM
08/22/16 11:44 PM
stick your head back up under there & listen intently for those 3 (or 4) clicks!
Re: 70 Roadrunner Turn Signal Problem [Re: RapidRobert] #2139082
08/23/16 01:15 AM
08/23/16 01:15 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...check between the steering column & the E-brake.
Re: 70 Roadrunner Turn Signal Problem [Re: thehemikid] #2139267
08/23/16 01:09 PM
08/23/16 01:09 PM
Port Reading, NJ
Port Reading, NJ
Thanks. Ill look again.
Re: 70 Roadrunner Turn Signal Problem [Re: roadrunner7070] #2139318
08/23/16 02:46 PM
08/23/16 02:46 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Not to be smart but maybe time to buy a factory service manual.Best money you will spend.Rocky
Chrysler Firepower
Re: 70 Roadrunner Turn Signal Problem [Re: therocks] #2139380
08/23/16 04:46 PM
08/23/16 04:46 PM
Port Reading, NJ
Port Reading, NJ
I have the factory service manual. It says on left side of steering wheel.
Re: 70 Roadrunner Turn Signal Problem [Re: roadrunner7070] #2139383
08/23/16 04:50 PM
08/23/16 04:50 PM
Port Reading, NJ
Port Reading, NJ
Thanks for the help guys. I found it. It was the same as the emergency flasher. There was a mount on the underside of the lower dash. Swapped it out with the emergency flasher and it worked. Bought the heavy duty 536 for $4 at my local guys store. Works great. Done!
Re: 70 Roadrunner Turn Signal Problem [Re: roadrunner7070] #2139415
08/23/16 05:37 PM
08/23/16 05:37 PM
New Mexico
JMCFAN Online content
JMCFAN  Online Content
New Mexico
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
