Charging system discharging, where to start looking?
#2139328
08/23/16 03:12 PM
08/23/16 03:12 PM
Posts: 2,403 WASHINGTON, PA
11secaarcuda
WASHINGTON, PA
Actually, I've already tried another voltage regulator, alternator, and my battery checked out OK. When the car is running, the gauge points towards the D on the gauge. I also have a digital readout gauge plugged into my cigarette lighter, and when I turn the car off, that gauge starts to go back up into the 12v range. I need to start chasing wires, but where is the best place to start? I'd line to streamline this diagnosis as much as possible. Thanks, Mike.
67 Dart GT 340 4 speed 70 AAR Cuda 408 6 barrel 96 Indy Ram original owner 2011 Hemi Durango
Re: Charging stem discharging, where to start looking?
[Re: 11secaarcuda]
#2139334
08/23/16 03:24 PM
08/23/16 03:24 PM
RapidRobert
'69 down box reg/single field terminal alt or '70 up flat reg/2 field terminal alt system? with key on, blue wire field terminal at alt (green if 69 down) and blue wire at reg needs to be hot. that'll get us started
[Re: RapidRobert]
#2139336
08/23/16 03:27 PM
08/23/16 03:27 PM
11secaarcuda
WASHINGTON, PA
70 up. Actually on my 70 Cuda.
[Re: 11secaarcuda]
#2139339
08/23/16 03:34 PM
08/23/16 03:34 PM
RapidRobert
Alright, and check continuity on the wire between the green terminals on the alt & reg. an alligator clip is an easy check on the alt field & on the reg a thin probe to get into the green wire terminal on the reg & pull the triangle connector off & confirm the female connectors are tight. with the reg being replaced I'm assuming it has a good ground to the firewall. first tho I would confirm fire to the blue wire terminals at alt/reg (thin probe on the blue wire terminal also). assuming all your hard components are OK, all that is left is a wiring (power side) or ground (return side) issue.
[Re: Paul_Fancsali]
#2139374
08/23/16 04:28 PM
08/23/16 04:28 PM
11secaarcuda
WASHINGTON, PA
Thanks, I'll start checking tonight (hopefully)
