Re: Trans Question-No Forward...slipped, have reverse
[Re: dvw]
#213932
02/04/09 04:53 PM
02/04/09 04:53 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Direct Clutch..Correction Chrysler calls it the rear clutch...I was a Ford Tech they call it a Direct Clutch...Here's a clutch & band apply chart... http://www.mopar1.us/clutchstall.html
[Re: 1_WILD_RT]
#213933
02/04/09 06:00 PM
02/04/09 06:00 PM
Posts: 25,786 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The direct clutch in a Torqueflite is the front clutch, the rear clutch is needed for all forward gears and is probably the source of the problem. (if the fluid level is corrected first)
When GM/Ford terminology is used on Mopars it creates some confusion. direct/forward= GM/Ford front/rear= Mopar.
[Re: 440PURSUIT]
#213936
02/04/09 10:23 PM
02/04/09 10:23 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Sounds as if the clutches are gone and it needs rebuild. Lame!
I have good units at the warehouse up north. Hmmmmm, what to do? I'll investigate choices tonite.
yeah w/ a chilly sittin' pool side.
[Re: 440PURSUIT]
#213939
02/05/09 05:28 PM
02/05/09 05:28 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Did you fill it up and try it?
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
