I'll jump on the ballast wagon you can check it with multi meter with key off I'm inclined to think it a dual sided ballast the current flows from post to post that are above or below each other you can check it for continuity with the ohm resistance setting on any cheap multi meter if you touch leads to pins above below each other # should drop or 0 if there is no change in the # when touching pins above/ below each other the ballast is in need of replacing or just do the previously mentioned plan b test jump top to bottom wires together
