Re: Big Block Headgaskets?
[Re: moparphilll]
#2139119
08/23/16 01:51 AM
08/23/16 01:51 AM
RapidRobert
you could go to www.moparchat.com then scroll down to & click on "circle track chat" then read thru Sanborns' cooling mods that are in a sticky at the top of the page. SB orientated but alot carries over & he's one of the sharpest in the country. it'll take you a good hour to read/reread/absorb it all but it is worth it then decide for yourself
[Re: moparphilll]
#2139125
08/23/16 02:01 AM
08/23/16 02:01 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I've wondered about this in the past. Even drilled a set of gaskets once to match the block. Seemed to work okay, but I can't suggest it. Last couple of times I've had mine off I've just installed them accepting the pattern and have found that it actually it stays cooler, and here's (I think) why: you want the water to run front to back through the block, then return through the head, utilizing the large passages at the front & back. I believe this keeps coolant moving all the way to the back, and keeps the water flowing in a pattern. If the coolant was allowed to flow down through the gasket too much, you'd get hot-spots as it wouldn't flow all the way to the back. At least this is what seems to make sense to me.
Basically, install them and ignore the desire to see the gasket passages align with the block & head passages. It works, don't sweat it.
[Re: moparphilll]
#2139143
08/23/16 03:03 AM
08/23/16 03:03 AM
Posts: 5,166 CT
GTX MATT
CT
Yeah they're supposed to be that way
[Re: moparphilll]
#2139212
08/23/16 10:46 AM
08/23/16 10:46 AM
Posts: 75,092 A Banana Republic near you.
JohnRR
This is nothing new , felpro, and others including current Mopar steel shim, headgaskets have been like this for decades and it doesn't cause problems in 99.9999% of cases .
[Re: moparphilll]
#2139323
08/23/16 03:06 PM
08/23/16 03:06 PM
Posts: 197 Milwaukee, WI
moparjimbo
Milwaukee, WI
I agree, I just chiseled out a clearly original set from a 40 year old untouched 440 and they had the slots like that...
1996 Viper GTS - UGR Twin Turbo 1500RWHP, 9.02 @ 167 on pump gas and DOT tire 1973 Challenger - 572 Indy Hemi 860HP 1975 Trailduster Convertible, 440 1967 Plymouth Fury Police Pursuit 2DR 505 Stroker 2004 Neon SRT4 modded www.milwaukeemopar.com
[Re: moparphilll]
#2139528
08/23/16 08:49 PM
08/23/16 08:49 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
They are suppose the be restricted. You just want to have a bit of flow to prevent steam/air pockets. The coolant flow goes from front of block to back of block, up through back of heads to front of heads to thermostat. Incorrectly enlarging the holes can show a lower thermostat temperature, but the back of the block will be running hot because you are bypassing the flow to the back of the block.
The exception to this might be increasing the hole to the next to last cylinder to help cool the center exhausts area of the head.
