Re: Rocker Arms for Big Block [Re: scrapmetal] #2138672
08/22/16 04:09 PM
08/22/16 04:09 PM
AndyF Offline
AndyF  Offline
Originally Posted By scrapmetal
I've been waiting for this Rocker arm company that went out and their employes are bring it back.They are having a hard time with their forger.I was told they are skipping them and are getting a neighbor to Cnc some .Should be out in 6 weeks.My machinist said when they were in business before that is was a good product
http://www.rockerarms.com/
Yep, RAS made the best rocker arms for BB Mopar engines but they aren't available anymore. I have a set of those rocker arms that I've used on a bunch of different engines over the years. Killer rocker arms, probably never sell these since I wouldn't be able to replace them.
Re: Rocker Arms for Big Block [Re: AndyF] #2138676
08/22/16 04:13 PM
08/22/16 04:13 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
So another company sells great rocker arms and is no longer......... work
Re: Rocker Arms for Big Block [Re: Bill MeLater] #2138679
08/22/16 04:16 PM
08/22/16 04:16 PM
Originally Posted By Bill MeLater
How do cup style adjusters get oiled properly?
They have to oil through the adjusters with pushrod oiling shruggyI say that but not all of them do that, my Jesel adjusters are hollow with no provisions to oil the valve stems or cups on the adjusters other than splash oiling from the pushrods oiling them through the center of them with pushrod oiling, there are no proviosn to oil the shafts or valve stem tips either on this paired shaft system confused
Re: Rocker Arms for Big Block [Re: Bill MeLater] #2139279
08/23/16 01:36 PM
08/23/16 01:36 PM
on my 273 iron rockers with the threaded adjuster removed I drilled a 1/8" hole horizontally thru the rocker on that side from the outside in & on thru the shaft all in a straight line clocked with the valve closed then drilled/tapped the outer hole in the rocker for a setscrew which stops high RPM oil castoff from it which is a waste & also helps lock the setscrew in place as some of em ain't tight enough (not enough interference fit on their threads)
