How abouts a parts weight database? I will start #21370
12/31/05 05:37 PM
12/31/05 05:37 PM
Houston, Texas
TheOtherDodge Offline OP
Houston, Texas
Started to pull apart the junk to access what I need.
Since everyone always asks what stuff weighs... Can break it down into the body styles. What do you think?
E Body:
Fenders: 34 lbs
Front lower valance: 6 lbs
Re: How abouts a parts weight database? I will start [Re: TheOtherDodge] #21371
12/31/05 06:30 PM
12/31/05 06:30 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
side impact beams in challenger doors 22lb each
stock bucket seats 45 each
battery,tray and bracket 48lb
Re: How abouts a parts weight database? I will start [Re: sixpackgut] #21372
01/01/06 12:02 AM
01/01/06 12:02 AM
cincinnati ohio
mcat4321 Offline
mcat4321  Offline
cincinnati ohio
e body a/c heater box and blower 37 lbs
Re: How abouts a parts weight database? I will start [Re: mcat4321] #21373
01/01/06 09:10 AM
01/01/06 09:10 AM
66-67 BBody
Internal AC Box / Blower / Heater Core - 52 lbs.
Power Steering box/pump/lines - 45 lbs.
Front Bucket Seat - 51 lbs.
Center console - 22 lbs.
Stock Flat Hood with brackets - 69 lbs.
Stock 8.75" housing/Moser 4.10 spool chunk/Moser Axles/drum Brakes - 212 lbs
Fifty Lb balast bar - 50lbs.
Re: How abouts a parts weight database? I will start #21374
01/01/06 11:21 AM
01/01/06 11:21 AM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline
VanishPt  Offline
V
70 Challenger
p/S box--35# 11Oz
t Bars pair of .96, 17# 12 oz
uc arms pair 10# 1 oz
bare k frame 37# 15 oz
pair of bare spindles 12#
front 10" front drum brakes pair 64# 9 0z
k frame as dropped out of car with steering box, all bolts ( no shocks or UC arms) 208 lbs
weight of everything in above 236#
15 x8 bare ralley wheel 25# 11 oz
outer front bumper bracket 9# pair
inner 10# pair
Hooker headers for Hemi 33# pair
stock rear axle 19# 7 oz each
rear spring 39 # 9oz each
rear bumper, bolts and brackets 26# 1oz
front bumper ,brackets and bolts 35#
bucket seat 46# 8 oz
steering column 24 # 2oz
door beam 24# 7 oz
empty 727 (no tc) 129#
indy single 4 intake 20#
rear 10" drum 12# 6 oz each
PS pump with brackets 13 # 7 oz
Re: How abouts a parts weight database? I will start [Re: VanishPt] #21375
01/01/06 11:52 AM
01/01/06 11:52 AM
Is there anyway I can add this to Harpos weights for a 66-7 b-body? Anyway..
Back seat 45#
Front bumper w/o brackets 25#
This is a great idea!
Re: How abouts a parts weight database? I will start [Re: TheOtherDodge] #21376
01/01/06 02:16 PM
01/01/06 02:16 PM
BC, Canada
Black_Bee Offline
Black_Bee  Offline
BC, Canada
1969 Super Bee:
  • Stock "Power Bulge" hood: 62.5lbs
  • AAR Bolt On Six Pack Hood: 28lbs
  • Stock front drum brakes: 39lbs/side
  • Wilwood Heavy Duty disk brakes: 18lbs/side
  • Stock Big Block starter: 17.5lbs
  • Mini Starter (93 Ram): 8.5lbs
  • 906 head: 50lbs
  • Edelbrock RB head: 29lbs
Paul
'69 Super Bee 383 EFI Turbo
Re: How abouts a parts weight database? I will start [Re: TheOtherDodge] #21377
01/03/06 10:44 AM
01/03/06 10:44 AM
fullmetaljacket Offline
FULLMETALJACKET HERE.
Been away on a falling business for a while and now back.
The following parts while the car was dismantled for painting were double checked on a second scale and then put back on the car unless other wise (Deleted) or (Replaced).
This car hasn't an ounce of fiberglass/carbon fiber on its skin and is street driven to and from the races/car shows. WORD.
Defendant: 65' Dodge Coronet two door post.
Front fenders: 58 1/2 lbs for the pair.
Stock Hood: 68 lbs. Gutted carb hole opening with A990 Hemi hood scoop: 79 lbs.
Hood hinges locking latch misc hardware: 13 1/4 lbs. 4-steel hood pins, replaced.
Front wheelwell and headlight splash panels: 11 lbs.
Power steering box, pump , belt, misc. hardware: 49 lbs. manual steering box, replaced.
Master brake cylinder: 6 1/2 lbs.
Front fold down bench seat, belts, mounting hardware: 100 lbs. A-100 bucket seats, replaced.
Rear two piece seat: 56 lbs. (deleted)
Stock radio: 6 1/2 lbs. (deleted)
Heater unit, ducts, switches and misc: 27 lbs. (deleted)
Re: How abouts a parts weight database? I will start [Re: fullmetaljacket] #21378
01/03/06 11:47 AM
01/03/06 11:47 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
bare mp hemi head 81
bare 906 head 46
bare max wedge head 39
bare T/A head 46.5
69.5 six pack intake and carbs 35.5
hemi intake and carbs 38
71 340 tq intake and carb 42.5
72 400 tq intake 36
70 340 intake and carb 53
70 440 intake and carb 43
max wedge intake and carbs 37.5
340+6 intake 25
340 cast crank 52.5
383 steel crank 71
400 cast crank 63.5
440 cast crank 69
360 4in stroke crank 60.5
340 4in stroke crank 57
big block 4.150 mp crank 82
big block 4.150 440 source crank 72
max wedge ex manifold L 31 R 27.5
big block a body ex manifolds L 16.5 R 13.5
68 to 70 340 ex manifolds L 12.5 R 14
71 440 hp ex manifolds L 20.5 R 16
71 340 ex manifold L 12.5 R 13
23 spline b+e body 4 sp 120
18 spline b+e body 4sp 127
10.5 130 tooth flywheel 30
8 3/4 sure grip center section 74
8 3/4 spool center section 61
e body 8 3/4 with axles without brakes 145
b body dana with axles without brakes 205
Re: How abouts a parts weight database? I will start [Re: TheOtherDodge] #21379
01/03/06 03:05 PM
01/03/06 03:05 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
entire front suspension for a body including k member
"237 lbs"
WAXER
Re: How abouts a parts weight database? I will start [Re: TheOtherDodge] #21380
01/04/06 10:10 AM
01/04/06 10:10 AM
Central Missouri - USA
Ramcharger Offline
super gas
Ramcharger  Offline
super gas
This would be a very neat addition to the Tech Archives after some more info gets added.
'64 Dodge 440 2 dr. sedan - 440/pushbutton 727 (in the body shop)
'99 Dodge 2500 Quad Cab Long bed 4WD - CTD 5 spd. 3.54
'89 Dodge 150 4x4 - 5.9 TBI/727 35x12.50's and 8" lift
'14 Dodge Dart Limited 2.4/6-speed A/T
Re: How abouts a parts weight database? I will start [Re: TheOtherDodge] #21381
01/04/06 01:13 PM
01/04/06 01:13 PM
B-low, N.Y.
JLDUSTER Offline
JLDUSTER  Offline
B-low, N.Y.
76 Dart Sport:
left/right window and all crank mech. 35# per side.
Re: How abouts a parts weight database? I will start [Re: TheOtherDodge] #21382
01/04/06 03:16 PM
01/04/06 03:16 PM
N of Detroit
DaveDudek Offline
DaveDudek  Offline
N of Detroit
69 Plymouth Dash complete with all assy 48lbs
69 Plymouth Dash radio delete, heater delete, map light delete 42 1/2 lbs
69 Plymouth bucket seats 44 1/2 lbs each
15x7 steel rim 24lbs
15x6 steel rim 22 1/2
Complete 69 Plymouth steering column 24 1/2 lbs
Cast Iron HEMI 4-speed case 33lbs
Alum HEMI 4-speed case 15lbs
Complete alum HEMI 4-speed 88lbs
Complete cast iron HEMI 4-speed 121lbs
727 TQ 120lbs
STK HEMI balancer 13lbs
STK 440 balancer 6lbs
Stock 70 Challenger hood 78lbs
T/A fiberglass factory hood 46lbs
Dave Dudek
1st Factory Stock legal car in the 10`s!!! [/b]
FAST & Factory Stock Rules: www.fastraces.org
FAST 69 Hemi RR 9.98@139
Re: How abouts a parts weight database? I will start [Re: Ramcharger] #21383
01/04/06 03:19 PM
01/04/06 03:19 PM
Central New Jersey
Ira Offline
super gas
Ira  Offline
super gas
Central New Jersey
this post has been saved, eventually it'll end up in the archives
Re: How abouts a parts weight database? I will start [Re: Ira] #21384
01/17/06 08:56 AM
01/17/06 08:56 AM
Front steel wheels 15"X4" with vintage Super Stock Formula 1 tires: 50 lbs. Pair.
Center line Auto drags with Moroso Drag specials: 25 lbs. Pair.
Re: How abouts a parts weight database? I will start [Re: fullmetaljacket] #21385
01/17/06 04:20 PM
01/17/06 04:20 PM
New Jersey
Craig Offline
Craig  Offline
New Jersey
You meant "each", not per pair right? I have Firestone Firehawk 7.75x14 on Cragar SuperTrick 3.5x15s and they are 22.5 lb each. Used to have Moroso Drag Specials 7.60x15 on these wheels and they were about the same.
67 Dart, 426 Hemi, 9.23/145mph, 3400lbs, footbraked, owned since 1982
Re: How abouts a parts weight database? I will start [Re: Craig] #21386
01/17/06 06:46 PM
01/17/06 06:46 PM
Sorry guy's, I meant each.
these parts are weighing down on my brain.
Re: How abouts a parts weight database? I will start [Re: fullmetaljacket] #21387
01/20/06 09:23 AM
01/20/06 09:23 AM
Indiana
Cuda_Mike Offline
Cuda_Mike  Offline
Indiana
35 spline power-loc suregrip for Dana 60,41 lbs.
35 spline Strange spool for Dana 60, 14 lbs.
Re: How abouts a parts weight database? I will start [Re: TheOtherDodge] #21388
01/20/06 09:37 AM
01/20/06 09:37 AM
Ramcharger Offline
super gas
Ramcharger  Offline
super gas
Last night, I ran across the old Hot Rod issue where Steve Magnante took something like 500 pounds off of his Duster. I could post the numbers on all those items if anyone would be interested.
Re: How abouts a parts weight database? I will start [Re: Ramcharger] #21389
01/20/06 06:24 PM
01/20/06 06:24 PM
Netherlands
72Challenger Offline
Netherlands
If you have the time, yes please post these #'s as I'm just in the process of putting the Duster back together after the painting and tubbing.
Thanks a lot!
