Re: Best Valve Cover Gasket Sealant? Hylomar or Gasgacinch??
[Re: 1964superstock]
#2138361
08/22/16 03:34 AM
08/22/16 03:34 AM
Posts: 43,218 Bend,OR USA
Cab_Burge
If you want to use a good gasket adhesive Gas A Cinch, it is your friend If your wanting to seal the gaskets up so they won't wick oil through them use Hylomar. BTW, I do use Gasket A Cinch as a gasket sealer on all sides on all my cork valve cover gaskets Do your cast aluminum valve covers have a flat sealing surface where the gaskets mate to or do they have a raised ridge in the center of the sealing surface? If flat your good, if with a raised ridge I have seen them split the valve cover gaskets in half with multiple reuses I'm going to have those ridges removed and make the sealing surface flat from now on
#2138364
08/22/16 03:49 AM
08/22/16 03:49 AM
Cab_Burge
Are your "cork" gasket pure cork or a cork and rubber mix? If mix use them, don't over tighten them when installing them Go back and retighten several times as needed after you start driving the motor I don't remember the factory torque specs. on the 1/4 inch rocker arm cover bolts or nuts, but it is not much I use snug them until the cover just touches the gasket and use another 1/8 to 1/4 turn tighter max after that
#2138368
08/22/16 04:05 AM
08/22/16 04:05 AM
Posts: 506 Utah, USA
1964superstock
Utah, USA
I have a set of Fel-Pro 1611 valve cover blue stripe cork-rubber gaskets. I also have a set of Fel-Pro "Fel-Co-Prene" VS 13379 R (black rubber) valve cover gaskets https://www.summitracing.com/parts/fel-1611"Blue StripeĀ® cork-rubber combines the qualities of cork and rubber gaskets. It maintains its shape and flexibility, yet is highly compressible. It seals well because of its good compressibility and is easier to install than synthetic rubber gaskets because cork-rubber is somewhat rigid." So you would recommend as #1 using the Fel-Pro blue stripe cork-rubber valve cover gaskets with Gasgacinch? How would this compare to using the black rubber gaskets with Hylomar?
#2138391
08/22/16 09:31 AM
08/22/16 09:31 AM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
Since both surfaces are machined I don't use any thing with the gaskets.
JAKES AUTOMOTIVE
[Re: JAKE68]
#2138438
08/22/16 11:20 AM
08/22/16 11:20 AM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
Since both surfaces are machined I don't use any thing with the gaskets. I Agree Also make sure your bolts are not to long , bottom out in heads and not sealing , or are you using studs ? And third Superformance Carbon X Valve Cover Gaskets
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
#2139576
08/23/16 10:26 PM
08/23/16 10:26 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I have come to depend on Permatex Aviation Form-A-Gasket for anything thats going to see oil. I run stock valve covers on aluminum heads and have found good success with the Fel-Pro rubber gaskets glued with the above referenced stuff into the valve covers, then onto the heads with no adhesive at the bottom sides of the gaskets.
