cylinder wall thickness
#2138335
08/22/16 01:47 AM
08/22/16 01:47 AM
Posts: 954 garnett kansas
rhad
garnett kansas
so ive been reading about how much a block can be bored,my question is what would be the minimum thickness of a cylinder wall,not a race motor,just a everyday grocery getter type car,how thick is the average wall on a new standard bore engine,be it mopar,chevy,ford,etc i had a john deere mower with a 14 horse kohler that somone had bored so much that they cut clear thru the cylinder and the cooling fins was the only thing holding the cyl together!!
my ladder of success is missing some rungs
Re: cylinder wall thickness
[Re: rhad]
#2138444
08/22/16 11:29 AM
08/22/16 11:29 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Average thickness? all over the place, only a sonic check can say what you have. Best plan is to bore minimally on anything other than an all out race motor. .030" over is usually the recommended max and I would not exceed that without a sonic check. Some info http://arengineering.com/tech/sonic-checking-the-mopar-big-block/
[Re: Tempest]
#2138467
08/22/16 12:00 PM
08/22/16 12:00 PM
Posts: 2,641 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I would not feel very comfortable with less than .150" on a mild performance motor. Good luck finding a BBM with that. I have 6 blocks here, all have cylinders under that at .030" over.
2011 Drag Pak Challenger
