Scuff plate extensions install? #2137911
08/21/16 02:27 PM
08/21/16 02:27 PM
68gtx Offline OP
68gtx  Offline OP
68 GTX scuff plate extensions. I have a hole on one end and open U shape on the other end. I know where it goes but not exactly how it screws in what goes where. Any picture or help appreciated. Its almost done!!!
Re: Scuff plate extensions install? [Re: 68gtx] #2137916
08/21/16 02:32 PM
08/21/16 02:32 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: Scuff plate extensions install? [Re: DAYCLONA] #2137923
08/21/16 02:41 PM
08/21/16 02:41 PM
68gtx Offline OP
68gtx  Offline OP
Thank you!!!!
Re: Scuff plate extensions install? [Re: 68gtx] #2137924
08/21/16 02:42 PM
08/21/16 02:42 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
the U shape tucks under the sill plate as pictured above and is held there by the sill plate screw. there will be a hole corresponding by the back seat which you may have covered with carpet.
Re: Scuff plate extensions install? [Re: 68gtx] #2137953
08/21/16 03:39 PM
08/21/16 03:39 PM
68gtx Offline OP
68gtx  Offline OP
I did cover it and I was not sure if the U went towards the front or not? I got 1 side in looks good.
Re: Scuff plate extensions install? [Re: 68gtx] #2137978
08/21/16 04:22 PM
08/21/16 04:22 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i remember thinking back in the day when i installed mine how nice it looked. a surprising small piece of trim makes it look complete! up
Re: Scuff plate extensions install? [Re: 68gtx] #2138078
08/21/16 07:10 PM
08/21/16 07:10 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Install them on the correct side. The one in the photo doesn't look right - maybe its just the angle - but I think the fit is better than that.
Re: Scuff plate extensions install? [Re: Stanton] #2138143
08/21/16 09:11 PM
08/21/16 09:11 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
The one in the photo is correct, the open "U" shaped end goes under the main door sill plate
