six pack carb base gaskets- where to get the good ones #2137789
08/21/16 12:10 PM
08/21/16 12:10 PM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
I forgot to buy them so I got online and it seems nobody carries them anymore? I see Jegs sells the grey ones but I thought those were too thin?
Re: six pack carb base gaskets- where to get the good ones [Re: jcastle1] #2137984
08/21/16 04:33 PM
08/21/16 04:33 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Superformance gaskets are what you want. Mancini's and some others carry the line.
Base gaskets
Good luck! up
Re: six pack carb base gaskets- where to get the good ones [Re: A990] #2138007
08/21/16 05:00 PM
08/21/16 05:00 PM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
I saw those on Mancini's site but wasn't sure if they were specific to the 6 barrel carbs. Any idea how thick they are? I've always used the MP paper gaskets
Re: six pack carb base gaskets- where to get the good ones [Re: jcastle1] #2138115
08/21/16 08:07 PM
08/21/16 08:07 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Another option (on pg 4)
Gibson restoration
Re: six pack carb base gaskets- where to get the good ones [Re: jcastle1] #2138294
08/22/16 12:26 AM
08/22/16 12:26 AM
Vancouver, WA
Cuda Cody Offline
Cuda Cody  Offline
Vancouver, WA
1970 Challenger T/A 4-Speed
1970 Challenger T/A Auto
1970 Challenger R/T Auto
1970 Challenger Auto
1970 Challenger RT 440+6 4-Speed
1970 Hemi Challenger 4-Speed
1970 Hemi Cuda 4-Speed
1971 Cuda Auto
1971 Cuda 4-Speed
LOOKING to BUY 1970 & 1971 E Body J, V and R Code project cars
Re: six pack carb base gaskets- where to get the good ones [Re: jcastle1] #2138328
08/22/16 01:36 AM
08/22/16 01:36 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Fel pro 1904
Re: six pack carb base gaskets- where to get the good ones [Re: scatpacktom] #2138423
08/22/16 10:57 AM
08/22/16 10:57 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Thickness matters and whatever you use make sure the carb base is flat,90% have the corners pulled down from over tightening.
Re: six pack carb base gaskets- where to get the good ones [Re: jcastle1] #2138729
08/22/16 05:25 PM
08/22/16 05:25 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
I thought this was the go to kit with the good base gaskets?
https://www.amazon.com/Genuine-Mopar-P4529060-Pack-Gasket/dp/B003TQBZOM
Re: six pack carb base gaskets- where to get the good ones [Re: jcastle1] #2138934
08/22/16 09:58 PM
08/22/16 09:58 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
If your carbs and manifold are flat, the thicker gasket will have a better chance of leaking with time.
I believe some are under the impression a thick gasket is better, but in reality are compensating for another issue.
I've used the thin one Scott sends with rebuilds and have no issues
Re: six pack carb base gaskets- where to get the good ones [Re: 70440+6bbl] #2139077
08/23/16 01:12 AM
08/23/16 01:12 AM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
it is, nobody stocks them. says it will ship within 1 or 2 months?
Re: six pack carb base gaskets- where to get the good ones [Re: jcastle1] #2139093
08/23/16 01:21 AM
08/23/16 01:21 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
They have been on back order since April.
Re: six pack carb base gaskets- where to get the good ones [Re: jcastle1] #2139460
08/23/16 06:59 PM
08/23/16 06:59 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
I use the ones Promax sells.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: six pack carb base gaskets- where to get the good ones [Re: jcastle1] #2140406
08/25/16 02:31 AM
08/25/16 02:31 AM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
I ended up getting the ones from Superformance. Wow! Great, friendly customer service, quick shipping, and a great looking thick gasket!
