904 low gear set, how to tell?? #2137436
08/20/16 08:00 PM
08/20/16 08:00 PM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
I have these two gear sets and sun gears. Can you tell me which is which?
Thanks in advance!
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: 904 low gear set, how to tell?? [Re: DemonDust] #2137462
08/20/16 08:56 PM
08/20/16 08:56 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
2.74 low is on the left.
BTW, the pic shows two ring gears and two planitary sets, the sun gears are missing.
Re: 904 low gear set, how to tell?? [Re: DemonDust] #2137468
08/20/16 09:10 PM
08/20/16 09:10 PM
Menomonee Falls
Menomonee Falls
So the steel is the low gear set?
Sorry they were off to the side. I thought I got them in the pic when I took it. I must have posted the wrong pic.
SDG Motorsports
Re: 904 low gear set, how to tell?? [Re: DemonDust] #2137470
08/20/16 09:15 PM
08/20/16 09:15 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Correct
Re: 904 low gear set, how to tell?? [Re: B5 Bee] #2138001
08/21/16 04:53 PM
08/21/16 04:53 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Not all steel carriers are the low gearset, the steel carriers were introduced in '74...long before the low gearset.
Re: 904 low gear set, how to tell?? [Re: DemonDust] #2138010
08/21/16 05:04 PM
08/21/16 05:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Do me a favor.. measure the diameter of
both.. I did on the screen and it shows
different.. but that might be my screen or
your camera angle
wave
Re: 904 low gear set, how to tell?? [Re: MR_P_BODY] #2138390
08/22/16 09:30 AM
08/22/16 09:30 AM
moparx Offline
moparx  Offline
i have a steel planet set pn 37434476. is that a low gear set or regular ? is there a way to count the gear teeth to tell ? are the spline counts and pressure angles of the splines the same between gear sets ?
beer
Re: 904 low gear set, how to tell?? [Re: DemonDust] #2138395
08/22/16 09:43 AM
08/22/16 09:43 AM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
There is a difference in the sun shell. The low gear shell has a ridge along the bottom to accommodate the taller sun gear. Low gear set on the left.
The reason for the ridge on the shell is because the sun gears are slightly different. Low gear sun on the bottom.
Couple more low gear set pics.
Gears are worn on this one.
Sun shell.
'71 Duster
'72 Challenger
'17 Ram 1500
Re: 904 low gear set, how to tell?? [Re: RMCHRGR] #2138413
08/22/16 10:35 AM
08/22/16 10:35 AM
moparx Offline
moparx  Offline
thanks for the reference pics. the set i have must be the standard set. by looking at the 6th pic where the pinion axles are welded to the case half opposite the hub with the snap ring groove, i have four round holes present, where your pic shows four square notches with the bottom of the notch opening into the case inner bore. or were there variations of this and possibly another quick way to identify the low gear set from the standard ?
beer
Re: 904 low gear set, how to tell?? [Re: moparx] #2138474
08/22/16 12:07 PM
08/22/16 12:07 PM
Tucson, Arizona
clonestocker Offline
Tucson, Arizona
Don't forget to weld the steel planet. Redo the factory weld and weld the fillet. Taken many apart that were pre-broken.
[img] [/img]
Re: 904 low gear set, how to tell?? [Re: clonestocker] #2138478
08/22/16 12:12 PM
08/22/16 12:12 PM
moparx Offline
moparx  Offline
you are so right ! those welds on mine look like they were done by just pointing the gun in the general direction and pulling the trigger ! just sloppy workmanship in my opinion. i'm guessing the welding operation was automated ?
beer
Re: 904 low gear set, how to tell?? [Re: MR_P_BODY] #2138769
08/22/16 06:42 PM
08/22/16 06:42 PM
Menomonee Falls
Menomonee Falls
your camera angle
wave
The low gear set measures 5.0645. The stock aluminum set measures 4.4965
SDG Motorsports
Re: 904 low gear set, how to tell?? [Re: DemonDust] #2138779
08/22/16 06:56 PM
08/22/16 06:56 PM
Menomonee Falls
Menomonee Falls
I did reweld them. I started going around one then I felt like it was getting too hot so I stopped. The rest I just went over the factory weld. How far do you guys weld them?
SDG Motorsports
Re: 904 low gear set, how to tell?? [Re: DemonDust] #2138801
08/22/16 07:18 PM
08/22/16 07:18 PM
Tucson, Arizona
Tucson, Arizona
I'm talking about the snout on the other end of the planetary and the base you can see in your picture.
[img] [/img]
Re: 904 low gear set, how to tell?? [Re: clonestocker] #2138916
08/22/16 09:32 PM
08/22/16 09:32 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Do you have a pic of this done?
Re: 904 low gear set, how to tell?? [Re: cudaman1969] #2139024
08/23/16 12:06 AM
08/23/16 12:06 AM
Tucson, Arizona
Tucson, Arizona
You weld in the fillet area.
[img] [/img]
Re: 904 low gear set, how to tell?? [Re: DemonDust] #2139158
08/23/16 04:56 AM
08/23/16 04:56 AM
Menomonee Falls
Menomonee Falls
Cat hair is optional....
SDG Motorsports
Re: 904 low gear set, how to tell?? [Re: DemonDust] #2139160
08/23/16 05:02 AM
08/23/16 05:02 AM
Menomonee Falls
Menomonee Falls
Dang.... Now that the the trans is together I see this. I'm guessing this is the weld you guys were talking about? Maybe I'll pull it back apart this winter and redo all the factory welds on the low gear set.
SDG Motorsports
Re: 904 low gear set, how to tell?? [Re: DemonDust] #2139161
08/23/16 05:03 AM
08/23/16 05:03 AM
Menomonee Falls
Menomonee Falls
So you weld both sides of the planetary on the gear set? Or just the factory welded side?
SDG Motorsports
Re: 904 low gear set, how to tell?? [Re: DemonDust] #2139228
08/23/16 11:24 AM
08/23/16 11:24 AM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
Gouge.
'71 Duster
'72 Challenger
'17 Ram 1500
