Re: 904 low gear set, how to tell??
[Re: B5 Bee]
#2138001
08/21/16 04:53 PM
08/21/16 04:53 PM
Posts: 25,858 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Not all steel carriers are the low gearset, the steel carriers were introduced in '74...long before the low gearset.
[Re: DemonDust]
#2138010
08/21/16 05:04 PM
08/21/16 05:04 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Do me a favor.. measure the diameter of both.. I did on the screen and it shows different.. but that might be my screen or your camera angle
[Re: moparx]
#2138474
08/22/16 12:07 PM
08/22/16 12:07 PM
Posts: 2,155 Tucson, Arizona
clonestocker
Tucson, Arizona
Don't forget to weld the steel planet. Redo the factory weld and weld the fillet. Taken many apart that were pre-broken.
[img] [/img]
[Re: MR_P_BODY]
#2138769
08/22/16 06:42 PM
08/22/16 06:42 PM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
Do me a favor.. measure the diameter of both.. I did on the screen and it shows different.. but that might be my screen or your camera angle The low gear set measures 5.0645. The stock aluminum set measures 4.4965
[Re: DemonDust]
#2138801
08/22/16 07:18 PM
08/22/16 07:18 PM
clonestocker
Tucson, Arizona
I did reweld them. I started going around one then I felt like it was getting too hot so I stopped. The rest I just went over the factory weld. How far do you guys weld them? I'm talking about the snout on the other end of the planetary and the base you can see in your picture.
[img] [/img]
[Re: clonestocker]
#2138916
08/22/16 09:32 PM
08/22/16 09:32 PM
Posts: 8,288 fredericksburg,va
cudaman1969
fredericksburg,va
I did reweld them. I started going around one then I felt like it was getting too hot so I stopped. The rest I just went over the factory weld. How far do you guys weld them? I'm talking about the snout on the other end of the planetary and the base you can see in your picture. Do you have a pic of this done?
