Re: transmission diagnosis....I think I already know the answer
[Re: 68DART360]
#2137295
08/20/16 03:29 PM
08/20/16 03:29 PM
Posts: 11,692 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Rear band applies in reverse. It will also apply in low if the VB is LBA. If it is not LBA, it relies on the roller clutch to hold the drum in low. Still should run in 2 or 3 unless something else is broken. Regardless, it needs to come out and be closely inspected. No way should it be run.
[Re: 68DART360]
#2137311
08/20/16 03:46 PM
08/20/16 03:46 PM
Posts: 25,967 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Hey guys, I broke the ring gear on my car a few weeks ago on launch. I replaced the ring and pinion and when I started the car on the jack stands, I only get reverse gear. Jack stands is the absolute worst place to test an automatic transmission's function.
[Re: John_Kunkel]
#2137717
08/21/16 10:09 AM
08/21/16 10:09 AM
Posts: 75,092 A Banana Republic near you.
JohnRR
[Re: 68DART360]
#2137964
08/21/16 03:56 PM
08/21/16 03:56 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
With the engine running, trans not in park, everything is going to rotate whether the thing is in gear or not. On jack stands, you will have to drag the brakes to get some load on it to get any idea of what it's doing.
[Re: 68DART360]
#2137976
08/21/16 04:16 PM
08/21/16 04:16 PM
John_Kunkel
Rio Linda, CA
No forward gears means the rear clutch isn't engaging, probably a broken Belleville or blown piston seals....air test will tell.
In Reverse the rear planetary is driven directly from the front clutch, even if the front planetary was missing you'd still have Reverse.
