Re: Tubes or no tubes? [Re: rowin4] #213712
02/04/09 07:35 PM
02/04/09 07:35 PM
Riverside, California
Lil Demon Offline
Lil Demon  Offline
If installed correctly they won't wad up, every one i have changed out never had a wrinkle in them. If installed correctly , having the tire desoaped, is that a word? [ cleaned and dry ] then use lots of tire talc to keep the tube from binding you'll have no problem.
OK then - have you ever seen one ripped? I saw a really nice 68 Cuda almost eat a wall and there was no evidence as to why, until he got home and decided to check the tube.
Re: Tubes or no tubes? [Re: rowin4] #213713
02/04/09 07:40 PM
02/04/09 07:40 PM
i tried no tubes in my 65 plymouth for 1 season, every week the slicks were flat. car is on the lift now getting a engine swap and just took the slicks off and put tubes back in.couldnt take the hassle of airing them up every weekend.
just hope the tube doesnt blow again this year.
Re: Tubes or no tubes? #213714
02/04/09 07:57 PM
02/04/09 07:57 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Mine hardly loses air (maybe its the no screws)
I think 8 lbs per square inch will firmly hold them in case i go drifting
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Tubes or no tubes? [Re: bigdad] #213715
02/04/09 09:31 PM
02/04/09 09:31 PM
O'Fallon,IL.
70RTRacer Offline
70RTRacer  Offline
O'Fallon,IL.
No tubes here.
Re: Tubes or no tubes? [Re: 70RTRacer] #213716
02/04/09 10:26 PM
02/04/09 10:26 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
We use tubes.
Nautilus Racing-
Re: Tubes or no tubes? [Re: Chris2581] #213717
02/05/09 12:34 AM
02/05/09 12:34 AM
Alexandria, VA
SealockRacing Offline
Alexandria, VA
this has me wondering if i should pull the tubes out of my slicks.
the left rear goes flat in about 4 days and the right rear hasnt lost a lb.
could i use bead sealer to help seal the bead to the wheel, and then some silicone on the wheel screws to ensure no/ less leaks?
what would i use as far as a valve stem? would a regular(free) rubber one work from my job, or do i need a special one? which is prefered.
probably going to make the switch soon depending on answers!
John
Re: Tubes or no tubes? [Re: flatiron] #213718
02/05/09 12:46 AM
02/05/09 12:46 AM
For your car I would run(and do) the M/T ET Street Bias plys or the ET STreet Radails, as large as you can fit in the car. I don't use tubes in the bias ply tires and the radials don't need them. As far as wadding up a tube in the car after it was mounted correctly I have done that with Mr Murphys help, I let the pressure down to low and bingo on that run it wadded up the tire and starting shaking like a bad dog in high gear It took a while to figure that one out the tire was in balance before the run and no weights had come off the rim and it was really out of balance after that run I quit using tubes in drag slicks under the advise of the Firestone tire guys at the races back in 1978. I have also split a tube in high gear in a stick shift Hemi car in 1976 , no fun on that run either, I thought I was going to mess the piant and body work up big time Good luck on your decision, no matter waht it is
Re: Tubes or no tubes? [Re: SealockRacing] #213719
02/05/09 01:00 AM
02/05/09 01:00 AM
Eagleville Tn.
rtstreet Offline
rtstreet  Offline
Eagleville Tn.
I run tubes now, but did not for along time, I really think it depends on how hard your set up hits the tire. In extreme we can not run the w tire so i run the "s" for two seasons without tubes (maybe 7 or 8 sets) then added tubes, did not see any big et gain but seen more constant 60 and 330 foot times, way better to tune on
Re: Tubes or no tubes? [Re: rtstreet] #213720
02/05/09 01:16 AM
02/05/09 01:16 AM
USA
Ron Silva Offline
Ron Silva  Offline
USA
Hoosier Quick Time Pro's. No screws. No tubes. No dish soap. No loss of air. No problems whatsoever.
There are several problems you can run into with tubes and if you do not run screws with tubes you are crazy. Unless of course if you run excessive air pressure all the time. But what fun is that??
SRT DEMON ONE SEAT
Re: Tubes or no tubes? [Re: bigdad] #213721
02/05/09 01:54 AM
02/05/09 01:54 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
No tubes, No screws, I'm a rebel
you're my kinda guy
