Page 18 of 48 1 2 16 17 18 19 20 47 48
Re: Modern Bullitt build [Re: gch] #2122179
07/31/16 09:28 PM
07/31/16 09:28 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Originally Posted By gch
I admire you patience,dedication,and skills.
49 % Patience, 49 % dedication, 2 % skills ;-)
Thank you
Pat
Re: Modern Bullitt build [Re: Keepat] #2122180
07/31/16 09:29 PM
07/31/16 09:29 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
All primed!
Re: Modern Bullitt build [Re: Keepat] #2125901
08/05/16 05:45 PM
08/05/16 05:45 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
With the car completely epoxy primed I applied all the seam sealer on the exterior panels, starting with the roof drip rail. After sanding with 220 and a Scotch-Brite pad, l taped both the drip rail and roof to control the edge of the seam sealer. Using a product from 3M called Fast & firm #08505 I tooled it in using my finger and little lacquer thinner to keep i pliable. This Fast & Firm is easy to use and works great for paint or a vinyl top. I saved a small section of the original seem sealer to maintain the same shape.
Pat
Re: Modern Bullitt build [Re: Keepat] #2136046
08/18/16 06:22 PM
08/18/16 06:22 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Not much to show the last two weeks as I've been out of town but I did get some more some seam sealer done around the trunk and quarters.
Pat
Re: Modern Bullitt build [Re: Keepat] #2136449
08/19/16 08:47 AM
08/19/16 08:47 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Awesome work!
Re: Modern Bullitt build [Re: 69Cuda340S] #2136691
08/19/16 03:59 PM
08/19/16 03:59 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Originally Posted By 69Cuda340S
Awesome work!
Thank you sir!
Pat
Re: Modern Bullitt build [Re: Keepat] #2136984
08/20/16 12:33 AM
08/20/16 12:33 AM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
I agree!
Very nice work!
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Modern Bullitt build [Re: Keepat] #2138639
08/22/16 03:33 PM
08/22/16 03:33 PM
Maryland
rhamson Offline
rhamson  Offline
Maryland
Prepping the interior, jambs, engine compartment and trunk for finish paint before I get her off of the rotisserie. So many details and forgotten pet peeves I am tidying up along the way. It is just as well as the weather is lightening up with the humidity to paint. I am also collecting the suspension parts for the wheels to be mounted.
Re: Modern Bullitt build [Re: Keepat] #2138646
08/22/16 03:35 PM
08/22/16 03:35 PM
Maryland
rhamson Offline
rhamson  Offline
Maryland
Looking good Pat!
Re: Modern Bullitt build [Re: Hemi Allstate] #2139213
08/23/16 10:47 AM
08/23/16 10:47 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Originally Posted By Hemi Allstate
I agree!
Very nice work!
Mark
Thanks Mark!
Re: Modern Bullitt build [Re: rhamson] #2139218
08/23/16 10:56 AM
08/23/16 10:56 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Ralph, good to hear you are making progress on your car. Alex and I were talking about driving over to see you in his/your old Challenger soon!
Pat
Re: Modern Bullitt build [Re: Keepat] #2141203
08/26/16 11:03 AM
08/26/16 11:03 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Originally Posted By Keepat
Originally Posted By 71rm23
I just came across this build. I must be slow or something. Anyway, all I can say is WOW! I went through EVERY page. I'm blown away
I'm slow also, been working on his car for over two years and I think I have another year to go ;-) thanks for checking out the build.
Pat
I'm in the same boat. As a matter of fact my boat is still in storage! Lol
Pat I have a question for you. Do you get more satisfaction from doing the project or from driving it?
I get more from fixing things that enjoying them?
I could easily GET my car finished but then I think what do I do when Its done?
Anyways thanks for posting your progress.
Matt
Re: Modern Bullitt build [Re: MattW] #2141334
08/26/16 03:24 PM
08/26/16 03:24 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Pat
Matt
Hi Matt,
I enjoy the parts hunt and build the most, along with the 1st drive. I also like to drive the cars I build cross country, but that's about it. As this car has less then a year to go I'm already looking for the next project which will be a 194? Woody wagon for my wife. She help me with my 1st full restoration of a 1964 GTO back in the mid 80's so it's time for her to get back in the garage to help with her woody ;-)
Thank you
Pat
Re: Modern Bullitt build [Re: Keepat] #2141821
08/27/16 12:25 PM
08/27/16 12:25 PM
Superfreak
Superfreak
Wow!!!!
You definitely have some great fabricating skills and looks to be top notch quality. This will be one cool looking charger when done.
Robert
Re: Modern Bullitt build [Re: ] #2142121
08/27/16 09:12 PM
08/27/16 09:12 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Originally Posted By Superfreak
Wow!!!!
Robert
Robert,
Thank you! but when will it be done??? I'm working on the 3rd year of what I thought would be a two year build ;-(
Pat
Re: Modern Bullitt build [Re: Keepat] #2142559
08/28/16 04:58 PM
08/28/16 04:58 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Finished up 90% of the seam sealer including a lot of areas the factory did not do that I had to use a pick tool prior to priming to remove the stones, grease and grime from the past 50 years. The beige seam sealer is 3M's fast and firm #08505. Easy-to-use, you can smooth out with a wet finger and 2 hours later you can clean up any mistakes with a rag and lacquer thinner.
Re: Modern Bullitt build [Re: Keepat] #2144159
08/30/16 09:58 PM
08/30/16 09:58 PM
Oakley CA
69charger440_6pa Offline
Oakley CA
nicely done
1969 Charger R/T under construction
2014 Ram 3500 Cummins
2006 Corvette Z06
2015 Corvette Z06
2014 BMW M5
Re: Modern Bullitt build [Re: Keepat] #2153824
09/13/16 05:20 PM
09/13/16 05:20 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I've been laid up for a few weeks with some hernia surgery but I use this downtime to work on modifying the woodgrain steering wheel for the car. I love the look of the woodgrain wheel but driving my silver charger it was never comfortable handling the steering wheel as it's so thin. So I decided to modify this wood wheel to have a much larger modern size grip. I did not want to enlarge the diameter of the wheel as there already a little large compared to modern cars so I moved the inner ring in by about 3/8 of an inch. To do this I had to cut the S/S inner ring at all three spokes and weld it smaller in diameter and then Cut a new slot in all three spokes to hold the ring in its new location. While I have the steering wheel out for re-plating the spokes I need to brainstorm how I'm going to remake the larger plastic wood grain handle??? Suggestions welcomed!
Pat
Re: Modern Bullitt build [Re: Keepat] #2156139
09/17/16 10:28 AM
09/17/16 10:28 AM
Maryland
rhamson Offline
rhamson  Offline
Maryland
Sounds great. Just let me know when you guys plan on coming over. I would love to see my/his old car all done. I am now trying to get my car into the frame shop. The front rail is bent about 3/4" out of level. I have it off of the rotisserie and on it's wheels. I have also painted the interior and jambs to start hanging the sheet metal as soon as the frame is straight.
Re: Modern Bullitt build [Re: Keepat] #2170356
10/08/16 03:59 PM
10/08/16 03:59 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Still making progress just not a lot of photogenic things show. A lot of boring sanding to prep the bottom and engine well for base-coat clear-coat.
Pat
