Part Number for Tire Pressure Decal for 1969 U22 Tires? #2134828
08/17/16 12:13 AM
08/17/16 12:13 AM
USA
Detroit_Muscle Offline OP
USA
Does any one know the part number for the tire pressure decal for the 8.25x15 tires offered in 1969, option code U22? I have scoured the interwebs with no luck. I need to order one for my 1969 Fury that I'm restoring back to original.
Thanks!
Re: Part Number for Tire Pressure Decal for 1969 U22 Tires? [Re: Detroit_Muscle] #2134878
08/17/16 01:42 AM
08/17/16 01:42 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I'm pretty sure it's 3400479 (for "U27" 8.25 bsw & big-block "cop car") but I can't find a picture to confirm bump
blush ooops!
Re: Part Number for Tire Pressure Decal for 1969 U22 Tires? [Re: Detroit_Muscle] #2135036
08/17/16 12:09 PM
08/17/16 12:09 PM
USA
USA
Thanks. On the broadcast sheet the last digit of the tire pressure decal part number appears to be 1. I cant make out the next to last digit.
Re: Part Number for Tire Pressure Decal for 1969 U22 Tires? [Re: Detroit_Muscle] #2135186
08/17/16 03:48 PM
08/17/16 03:48 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
FWIW, my '69 Chrysler has the original sticker, a little the worse for age and wear. NOT ONE reproduction I've found is even close.
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Part Number for Tire Pressure Decal for 1969 U22 Tires? [Re: Detroit_Muscle] #2135262
08/17/16 06:14 PM
08/17/16 06:14 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
can you post or email a picture? the '69 broadcast sheets I have pics of with U22 have "79" for "TIRE LABEL"
Re: Part Number for Tire Pressure Decal for 1969 U22 Tires? [Re: 6bblgt] #2136338
08/19/16 12:39 AM
08/19/16 12:39 AM
USA
USA
Incredibly enough, I found a second broadcast sheet on top of the glove box! This one I can read the Tires digits and it is 71. I can email a pic of the sheet to you if you wish to see it.
Re: Part Number for Tire Pressure Decal for 1969 U22 Tires? [Re: 6bblgt] #2136361
08/19/16 01:14 AM
08/19/16 01:14 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Yes, I found some "71" coded "U22" sheets also - WAG #3400471
which had different loading and tire pressures based on OPTIONS on the vehicle (engine - A/C - etc.)
email me a copy of your sheet & I'll see if I can figure the specific application of the "71" VS. "79" label
dhead68 AT hotmail.com
Re: Part Number for Tire Pressure Decal for 1969 U22 Tires? [Re: 6bblgt] #2136433
08/19/16 04:44 AM
08/19/16 04:44 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
looks like scope & best guess at full part number
1969 Dodge/Plymouth c-body with:
big block & U22 = 3400483
small block & U22 = 3400471
I doubt reproductions exist, but if you can get a picture of one of the correct labels - I'm sure someone could make a few on a home computer & quality printer
Re: Part Number for Tire Pressure Decal for 1969 U22 Tires? [Re: 3hundred] #2136434
08/19/16 04:46 AM
08/19/16 04:46 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Robert
is it 8.55x15 and #3400484? & can you post a picture?
Re: Part Number for Tire Pressure Decal for 1969 U22 Tires? [Re: Detroit_Muscle] #2136932
08/19/16 11:19 PM
08/19/16 11:19 PM
USA
USA
The plot thickens. I found a pic of a 3400471 decal and its for 7.75x15 tires. So it may be possible that the U22 code is incorrectly documented as 8.25x15 or there is an error on the build sheet for the Tires.
Re: Part Number for Tire Pressure Decal for 1969 U22 Tires? [Re: Detroit_Muscle] #2136972
08/20/16 12:21 AM
08/20/16 12:21 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
sometimes the "base" tire label shows the "MINIMUM SIZE REQIUIRED" scope got pics?
if the tire pressure & load remained the same
in the mid-'70s Chrysler Corp. started using more of a generic tire label VS. one for every available tire size
Re: Part Number for Tire Pressure Decal for 1969 U22 Tires? [Re: 6bblgt] #2136976
08/20/16 12:25 AM
08/20/16 12:25 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Robert
I'll get one up quick as I can. You've got the right tire size, cannot recall the number off hand.
Robert
'69 300 Convertible
'16 300 S Hemi
Re: Part Number for Tire Pressure Decal for 1969 U22 Tires? [Re: 3hundred] #2138035
08/21/16 05:53 PM
08/21/16 05:53 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Don't know what's on the decal, black rubbery substance. Sticker number appears to be 3400484?
Attached, just for kicks, added what's left of the selling dealers service sticker.
Robert
'69 300 Convertible
'16 300 S Hemi
Re: Part Number for Tire Pressure Decal for 1969 U22 Tires? [Re: 3hundred] #2138056
08/21/16 06:16 PM
08/21/16 06:16 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I'd bet that's remaining glue from another service sticker
thanks for posting pics!
