Page 1 of 3 1 2 3
Welders in the house? Disaster strikes! #2136208
08/18/16 10:25 PM
08/18/16 10:25 PM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
Tonight I was working on pulling the 42RH transmission from my Duster to change out the kickdown lever and installed better clutches and steels and I enlisted my eldest son to give me a hand moving it from the cart to the floor. He's at that awkward late teen stage and I try to do stuff with him otherwise if left to his own device drifts towards video games and such.
Long story short the transmission got away from him and the bell housing went bouncing off the garage floor.
*^&^())_!
As you can see I now have this wonderful addition to the case.
Racing in a few weeks not looking so good, Murphy strikes again!
Can the case be welded up with a mig? I figure I have nothing to loose at this point and a lot of time and some money invested in the transmission. It doesn't look like a high stress area. We have a nice Lincoln MIG at work and do a lot of aluminum welding but none of it is cast. One of our drivers use to weld aluminum over at Electric Boat and I was thinking about letting him take a crack at it.
Thanks for any input!
"I think its got a hemi"
Re: Welders in the house? Disaster strikes! [Re: gdonovan] #2136216
08/18/16 10:33 PM
08/18/16 10:33 PM
georgia
intenseneon Offline
intenseneon  Offline
georgia
I had a bud weld the crack on my trans case, still holding up after 5 years, he heated it up to burn out the impurities.
69 Dart
Re: Welders in the house? Disaster strikes! [Re: gdonovan] #2136217
08/18/16 10:33 PM
08/18/16 10:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I've migged alum... V it out and preheat it.. I
normally do both sides.. make sure its clean
wave
Re: Welders in the house? Disaster strikes! [Re: gdonovan] #2136220
08/18/16 10:36 PM
08/18/16 10:36 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Drill a small hole at the end of the crack(stops it spreading) weld it up
Re: Welders in the house? Disaster strikes! [Re: rickraw] #2136221
08/18/16 10:39 PM
08/18/16 10:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yep.. drill the hole at each end
wave
Re: Welders in the house? Disaster strikes! [Re: gdonovan] #2136229
08/18/16 10:50 PM
08/18/16 10:50 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Clean, clean, clean. Do NOT use brakekleen.
Re: Welders in the house? Disaster strikes! [Re: gdonovan] #2136230
08/18/16 10:50 PM
08/18/16 10:50 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
Drill the end of the crack and run it.
Have a great day
Iowan
"obsolete is neat"
Re: Welders in the house? Disaster strikes! [Re: CMcAllister] #2136240
08/18/16 11:00 PM
08/18/16 11:00 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Or it could be the last welding you ever do. Great meeting you the other day Cole and boy did I hit rain on the way home. See you next week. Thanks
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Welders in the house? Disaster strikes! [Re: MR_P_BODY] #2136242
08/18/16 11:01 PM
08/18/16 11:01 PM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
Originally Posted By MR_P_BODY
I'd migged alum... V it out and preheat it.. I
wave
Doing both sides not a problem and the crack is all the way through.
Trying hard not to get mad at the kid, don't want to discourage him.
Re: Welders in the house? Disaster strikes! [Re: gdonovan] #2136264
08/18/16 11:19 PM
08/18/16 11:19 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
wave
I bet he feels worse then you do. I remember when I was 8, I was washing my dad's car with the very abrasive "Comet" clreaner, couldn't understand why the more I scrubbed, the browner It got (primer) eek . Might be a good time to share with him something yiu did as a kid that shows we all do things we are embarrassed about, but life goes on. Its a life lesson that can be fixed. Doesn't look like a highly stressed location, but the pic doesn't show much. I would not mig the crack, tig for me. If it gets vee'd to a point, from both sides, the crack will automatically be clean, regardless, don't get the crack wet without rapidly drying the crack, Drilling a hole achieves little if you are welding it before any use. The brake cleaner suggestions are spot on. twocents
Re: Welders in the house? Disaster strikes! [Re: gdonovan] #2136277
08/18/16 11:31 PM
08/18/16 11:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I had the tail shaft fall off my bench when I was
rebuilding the trans... broke a bolt ear off... I
V it out good and clamped a plate to it and welded
it back on... still running fine... I did have to
hit it on the belt sander to smooth it out.. no leaks
I tigged mine... with 1/8 rod for filler
wave
Re: Welders in the house? Disaster strikes! [Re: gdonovan] #2136307
08/19/16 12:01 AM
08/19/16 12:01 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Easy fix, as the guys have said clean. I would fully vee out, pre heat, weld and then vee out (back gouge) other side and weld again. Get the young gun to watch the repair.
1963 Plymouth Max Wedge
1971 Barracuda
Re: Welders in the house? Disaster strikes! [Re: jcc] #2136309
08/19/16 12:02 AM
08/19/16 12:02 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
wave
I agree the kid prob feels worse than you realize. That can be fixed no problem.
Re: Welders in the house? Disaster strikes! [Re: gdonovan] #2136331
08/19/16 12:35 AM
08/19/16 12:35 AM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
This cannot be stressed enough.
But personally, I'd drill the holes at each end, V it out a bit and leave it at that - no cleaning !! Why? Because its a fresh crack and should be clean. Trying to clean it could just make it worse. If its worth anything, why not take it to someone with a tig and have it done right. Mig welding aluminum is fine for high volume production but has no place where quality and durabilty are needed. And a good tig welder can be set up to "clean".
Re: Welders in the house? Disaster strikes! [Re: Stanton] #2136391
08/19/16 02:06 AM
08/19/16 02:06 AM
Randolph, Ohio--N.E. Ohio
Goat330 Offline
Goat330  Offline
pay someone to Tig weld it, chances are your little home mig machine doesn't have enough amps to get good penetration.
Re: Welders in the house? Disaster strikes! [Re: Goat330] #2136440
08/19/16 07:10 AM
08/19/16 07:10 AM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
Not a home rig, work unit with enough amps to smoke holes in 1/2 plate.
When it arrived we experimented with various settings to see how far we could push before stuff started getting out of hand. Impressive machine.
Re: Welders in the house? Disaster strikes! [Re: gdonovan] #2136452
08/19/16 09:05 AM
08/19/16 09:05 AM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
The big Lincoln Power Migs have more than enough juice, if you've got the spool gun or push pull gun setup for aluminum. Still going to want pre heat for a big casting like that. S/F....Ken M
Re: Welders in the house? Disaster strikes! [Re: gdonovan] #2136644
08/19/16 02:45 PM
08/19/16 02:45 PM
Mo.
racerx Offline
racerx  Offline
Mo.
?...with a very narrow crack like that what tool can be used to v that out for welding?......Thaxs
Re: Welders in the house? Disaster strikes! [Re: racerx] #2136648
08/19/16 02:49 PM
08/19/16 02:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I would just use my air grinder with a alum bit(semi pointed)
wave
Re: Welders in the house? Disaster strikes! [Re: racerx] #2136674
08/19/16 03:30 PM
08/19/16 03:30 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
The crack itself does not determine the v groove, the thickness of the part at the crack line does, and a 45deg is a good start. Both sides only if the part has decent thickness IMO
Page 1 of 3 1 2 3
