I cant ans the Q but is it an OE mechanical "box" type or a replacement electronic "box" type? Curious on the alt too, single or dual field terminal? EDIT on early A bodies at least, a flat triangle (later) reg will not fit in the squarish firewall recess without trimming one or both of its' side mounting flanges with the 2 mounting bolt holes. any feel on the wireing mods you mentioned at that area. EDIT in other words is there room on the firewall in the correct location for the flat later reg which might help us determine what it originally had
