Re: 4-Link Question
[Re: HR3128]
#2135176
08/17/16 03:33 PM
08/17/16 03:33 PM
Posts: 19,372 Las Vegas
Al_Alguire
Las Vegas
Probably....Are you saying both upper and lower bars on the dr side are longer than the pass side bars? Does it have a wishbone in it or a diagonal link? My guess is it was someones attempt to preload the car?!? Do yourself a favor and start over. Get the rear squared and get it on some scales.
Re: 4-Link Question
[Re: HR3128]
#2135189
08/17/16 03:54 PM
08/17/16 03:54 PM
Al_Alguire
Las Vegas
Does the car launch straight now?? If so it may have ben adjusted as it is to make it go straight. If it were me I would get the rear squared, possible make sure the housing is not bent as well and start over with scales. It SHOULD be in the car square but you never know how it was built. Possibly it is where it is to make it go straight? But I would want to star over. Square the rear and have Zero preload on the bars. Set the pinion angle and work from there. Rather than type it all out here is a link to some 4 link basics. It is a good reference point for someone new to them. http://www.racingjunk.com/forums/showthread.php?17130-4-Link-Basics-Theory-amp-Help-Instructions
Re: 4-Link Question
[Re: HR3128]
#2135197
08/17/16 04:11 PM
08/17/16 04:11 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Is this a back half car or full tube chassis... make sure the front bar is square in the car then start from the beginning.. if the other guy set it up like that to drive straight on the launch he did it all wrong and if it drives straight now.. something is built wrong
Re: 4-Link Question
[Re: MR_P_BODY]
#2135206
08/17/16 04:37 PM
08/17/16 04:37 PM
Posts: 430 Michigan
HR3128
Thanks for the replies. PlyCuda - I did the plum-bob/string layout to get these measurements. Al_A - Thanks for the link. I saw that google-ing around but did not read it all. I will now. Mr. P - It is a back half car. I have only made a couple trans-brake launches at part throttle & eased on the gas pedal. It did go straight.
Re: 4-Link Question
[Re: Monte_Smith]
#2135498
08/17/16 11:23 PM
08/17/16 11:23 PM
Posts: 4,728 Moved to N.E. Tennessee
GomangoCuda
FIRST thing to do is make sure the 4 link crossmember is square in the car. Does no good to square the rear to the chassis, if chassis isn't under the car square.
Assuming the brackets are square, placed on chassis and housing correctly.........meaning holes are same distance from housing centerline on both sides, clocked equally and brackets right on chassis, then you start squaring. First you make both bottom bars the same length and hang the housing and center it in wheel opening. Put upper left bar on and use this bar to set pinion angle. Then center housing from side to side under body and install wishbone. Upper right bar is last and with car on ground or platforms under tires, driver weight in seat, will install and be loose(no bind to get bolts in). The car is now square and has no preload. This is where you start. If it wants to go one way or another at launch, THEN you add positive or negative preload with upper right bar. I took Roy Hills 4link class almost 20 years ago and the procedure they taught was exactly the same as Monte explained. The Haas chassis they used had reference points built into it to measure the axle location from
Re: 4-Link Question
[Re: HR3128]
#2135544
08/18/16 12:12 AM
08/18/16 12:12 AM
Posts: 11,602 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Yep, check the chassis and the brackets. I have had to make bars different C-C lengths, had driveshafts not run exactly parallel with the chassis centerline, fool around with housing locators, etc., because chassis or housing brackets were on wrong, body panels were not right, pinion C/L location in the housing was wrong or whatever. All to get the housing square and straight to the centerline of a car that the owner didn't want to cut apart and make right. Some people just can't read a tape measure and a level.
Get the car up and level on a clean floor and start measuring and stringlining or lasering. Time consuming, but the alternative is to just center the tires between the fenders, get the housing squared close by stringlining the sidewalls forward and run it. Not what I would recommend
