Re: Cam for mild 440?
[Re: 440newport]
#213457
02/04/09 12:29 AM
02/04/09 12:29 AM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
Look at Summits brand.I ran the bigger one in a 440 and it was good.That and the price for cam and lifters cant be beat.Its still in a 383 and its been running since 83.Rocky
Chrysler Firepower
[Re: therocks]
#213458
02/04/09 12:43 AM
02/04/09 12:43 AM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
mmm I like how the crower sounds on specs.
[Re: therocks]
#213459
02/04/09 09:31 AM
02/04/09 09:31 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
They were on sale for $62 w/ lifters! not sure if they still are. FWIW I ran the 224/234-465/488 cam in a pretty stock 440 in a 67 coronet w/ 3.91 to 12.90. It's a good cam it has power form off idle to 5400. I use one again in a minute.
[Re: gch]
#213461
02/04/09 10:42 AM
02/04/09 10:42 AM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
I put the smallest Summit in my 440, can't tell you how it is yet. I haven't even broke the motor in yet.
Moparlee
[Re: stubbs300 ]
#213463
02/04/09 12:08 PM
02/04/09 12:08 PM
Posts: 4,588 St. John's Newfoundland
440newport
I'll keep this very simple a caveman could do it. Ask yourself. What's the factory grind numbers on a stock factory cam? Now take those numbers and for the duration, add 10%. For lift, add .050" to those stock numbers and what do you come up with? Keep your choices within those parameters and you will have one sweet street machine.
That comes out to be a pretty big cam though... 237/248 at .50 and .505/.520 lift. Especially when we're talking stock converter, 3.23 gears, and manifolds.
5% is more reasonable I'd say, and would be similar to the Crower 271 cam.
[Re: BDS871Cuda]
#213467
02/04/09 03:03 PM
02/04/09 03:03 PM
Mr.Yuck
Brookeville, Md
Robbins, How small of a Summit cam. How big do they go?
We put a Summit cam and summit headers in a 77 1/2 ton 2wd dodge truck with 318. It was the Edelbrock performer copy and made good power for how cheap the cam and headers were.
Big one; Cam Style: Hydraulic flat tappet Basic Operating RPM Range: 2,200-5,000 Intake Duration at 050 inch Lift: 224 Exhaust Duration at 050 inch Lift: 234 Duration at 050 inch Lift: 224 int./234 exh. Advertised Intake Duration: 282 Advertised Exhaust Duration: 292 Advertised Duration: 282 int./292 exh. Intake Valve Lift with Factory Rocker Arm Ratio: 0.465 in. Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.488 in. Valve Lift with Factory Rocker Arm Ratio: 0.465 int./0.488 exh. lift Lobe Separation (degrees): 114 Camshaft Gear Attachment: 1-bolt Small one; Part Number: SUM-K6400 Cam Style: Hydraulic flat tappet Basic Operating RPM Range: 2,000-4,500 Intake Duration at 050 inch Lift: 214 Exhaust Duration at 050 inch Lift: 224 Duration at 050 inch Lift: 214 int./224 exh. Advertised Intake Duration: 272 Advertised Exhaust Duration: 282 Advertised Duration: 272 int./282 exh. Intake Valve Lift with Factory Rocker Arm Ratio: 0.442 in. Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.465 in. Valve Lift with Factory Rocker Arm Ratio: 0.442 int./0.465 exh. lift Lobe Separation (degrees): 112 Camshaft Gear Attachment: 1-bolt
big one:
[Re: Mr.Yuck]
#213468
02/04/09 06:53 PM
02/04/09 06:53 PM
Posts: 3,916 usa
lewtot184
usa
how about none of the above. look at a mopar performance 272-.445. its ground on 112 centers, installs at 110cl, 224@.050, 129@.200. very underated profile. works good with stock heads, valve springs, seals, and rockers. i use one in my 4000lb+ 69 r/t with stock converter and 3.23 gears. performs decent and has nice driviability. another option is comp cams magnum replacement, #21-305-4 222@.050 .464lift on intake, 226@.050, .464 lift on exhaust, 110 lobe centers); a real tire fryer when installed at the recommended centerline (106cl).
[Re: lewtot184]
#213469
02/04/09 08:17 PM
02/04/09 08:17 PM
Posts: 5,166 CT
GTX MATT
CT
how about none of the above. look at a mopar performance 272-.445. its ground on 112 centers, installs at 110cl, [Email]224@.050[/Email], [Email]129@.200.[/Email] very underated profile. works good with stock heads, valve springs, seals, and rockers. i use one in my 4000lb+ 69 r/t with stock converter and 3.23 gears. performs decent and has nice driviability. another option is comp cams magnum replacement, #21-305-4 [Email]222@.050[/Email] .464lift on intake, [Email]226@.050[/Email], .464 lift on exhaust, 110 lobe centers); a real tire fryer when installed at the recommended centerline (106cl).
I thought the 272 was 231/231@.050? I agree, I think its a really good cam, but summit has it listed at 231. Im thinking about buying it as I believe it was in the 440 in my GTX. Just want to make sure summit doesnt have it listed wrong, might make me rethink it if your spec were correct. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: GTX MATT]
#213470
02/04/09 08:42 PM
02/04/09 08:42 PM
Posts: 3,916 usa
lewtot184
usa
summit is just repearting mopar performance's "revised" numbers. the true .050 number is 224@.050, just like it was stated years ago. i've run 13.13 @ 106mph with that cam in a 4000lb+ 6/9 r/t, stock exhaust, stock converter, 3.23 gears, stock heads, 9.3:1 compression, six-pak, 225-70x15 t/a radials, and still get 15+mpg on the road. the 21-305-04 cam is a good profile but don't install it 106cl (as comp cams recommends) in a performance role. 110cl would be better for 1/4 mile use.
[Re: lewtot184]
#213471
02/04/09 09:17 PM
02/04/09 09:17 PM
Posts: 5,166 CT
GTX MATT
CT
summit is just repearting mopar performance's "revised" numbers. the true .050 number is [Email]224@.050[/Email], just like it was stated years ago. i've run 13.13 @ 106mph with that cam in a 4000lb+ 6/9 r/t, stock exhaust, stock converter, 3.23 gears, stock heads, 9.3:1 compression, six-pak, 225-70x15 t/a radials, and still get 15+mpg on the road. the 21-305-04 cam is a good profile but don't install it 106cl (as comp cams recommends) in a performance role. 110cl would be better for 1/4 mile use.
You have a PM! ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: GTX MATT]
#213472
02/04/09 09:52 PM
02/04/09 09:52 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
I'd go for the lunati voodoo you listed. having the aggressive ramps with short adv duration will make it a nice sleeper with a nice idle and great low end (yay cylinder pressure) while having as much power as the larger grinds. I wouldn't use the summit cam unless you're on a verry tight budget.
[Re: patrick]
#213473
02/04/09 10:20 PM
02/04/09 10:20 PM
Posts: 2,093 oberlin, Ohio
Rapid340
oberlin, Ohio
I think you might like like this extreme upgrade cam I sell. 224,230 .514,.529 110 lobe sep. (140, 148 at .200) I wouldn't go any bigger. ![](/ubbthreads/images/graemlins/drive.gif)
1971 Factory Appearing Duster 340 11.000 @ 122 mph
[Re: patrick]
#213474
02/04/09 10:21 PM
02/04/09 10:21 PM
Mr.Yuck
Brookeville, Md
FWIW my buddy put together a 69RR w/ stock bottom end 440 (probably 9-9.5:1) w/ Eddy heads, RPM intake and the VooDoo cam 513/533 I think? pretty much they same stuff I had as far as trans, stall and gear and I whooped him. 12.90@104 to 13.13@102. just saying I think the VooDoo would like more compression and higher shift points.
[Re: Rapid340]
#213475
02/04/09 10:41 PM
02/04/09 10:41 PM
Posts: 3,916 usa
lewtot184
usa
(140, 148 at .200)
i've ran that cam ground on 110 centers and really like it, but it may be a little soft on the bottom for a big car. neverthe less its a performer for a near stock or moderately modified 440.
