remote turbo? #2133777
08/15/16 08:00 PM
08/15/16 08:00 PM
NE Indiana
momopar Offline OP
momopar  Offline OP
NE Indiana
Bad idea?
Seems you would get alot of lag? Charge cooling should increase?
Thinking of putting a hair drier on an old iron v10.
Re: remote turbo? [Re: momopar] #2133805
08/15/16 08:27 PM
08/15/16 08:27 PM
dogdays Offline
dogdays  Offline
I have seen aftermarket setups that put the turbo near the rear bumper. I guess if there's no room in the engine compartment, any old place will do.
The turbo operates on the energy content of the gases. The long exhaust pipe leading to the turbo shouldn't add turbo lag from distance, as the gas is going maybe 200 ft/sec. But, over all that distance the gas is radiating heat to the outside, and that isn't available to spin the turbo. Still, even a 4-5 psi boost can be noticeable.
So I guess the idea is do what you can.
R.
Re: remote turbo? [Re: momopar] #2134212
08/16/16 11:26 AM
08/16/16 11:26 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
The turbine housing will likely need to be a bit smaller than a single turbo mounted under the hood. You loose energy when the exhaust cools down.
There will bit a bit more lag with the long run back to the engine but, again, a smaller turbine will keep the compressor wheel turning at low engine speeds and keep the lag under control.
- Stu Harmon
Re: remote turbo? [Re: momopar] #2134345
08/16/16 02:07 PM
08/16/16 02:07 PM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
You can wrap your exhaust to keep the heat in to help.
