1963 Polara headliner #2133701
08/15/16 06:24 PM
08/15/16 06:24 PM
Colorado
67plymouthman Offline OP
Colorado
Has anyone installed a headliner on a 63 Dodge b-body? It looks like the front and rear windshields need to come out??? Mine is the one with bows.
What headliner clips are people using?
Re: 1963 Polara headliner [Re: 67plymouthman] #2133711
08/15/16 06:34 PM
08/15/16 06:34 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Look for barbed retainers under the garnish moldings, they would grip the headliner as opposed to having to R&I glass.
On the sides, they likely use the folded clips (U-shaped) or more lengths of barbed retaining strips.
Re: 1963 Polara headliner [Re: 67plymouthman] #2133993
08/16/16 12:11 AM
08/16/16 12:11 AM
Colorado
Colorado
Are the front and back barbed retainers similar to 68 to 70 b-bodys?
The car is at the upholstery shop and I am unsure if he knows what he is doing.
Re: 1963 Polara headliner [Re: 67plymouthman] #2133995
08/16/16 12:12 AM
08/16/16 12:12 AM
Colorado
Colorado
Do you have a picture of the u clips?
Re: 1963 Polara headliner [Re: 67plymouthman] #2134047
08/16/16 01:17 AM
08/16/16 01:17 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
No photo. They're about 1/4" x 1/2" give or take, literally a U-shape, and if the car has its original headliner in it, they should be there if that's what was used.
You or the upholsterer might have to Google around a bit if someone here doesn't post better info or photos. Just a guess, but sounds like the upholsterer is younger than the car, haha.
Re: 1963 Polara headliner [Re: 67plymouthman] #2134641
08/16/16 08:41 PM
08/16/16 08:41 PM
Minn
SportF Offline
SportF  Offline
Minn
The windshield doesn't have to come out.
On the rear, it doesn't have to come out if you can access the barbs under the window gasket. But.....it is a lot easier if you take out the rear.
Re: 1963 Polara headliner [Re: SportF] #2134782
08/16/16 11:01 PM
08/16/16 11:01 PM
Colorado
Colorado
Thanks, any pictures of the clips or part numbers. I called Dantes and he said try the newer model b-body but they are different.
