SB Magnum head Q's #213363
02/03/09 09:17 PM
02/03/09 09:17 PM
ILLINOIS
V
volaredon Online content OP
volaredon  Online Content OP
V
ILLINOIS
I have 2 LA 318s that I'd like to swap magnum heads onto as well as a Mag 318 that I am building up for use in a volare. (3 engines total) I cannot seem to find a good (crack-free) set of Magnum heads, to save my life. Lots of money spent (free heads are far from "free")
$225 for a set off a 380 crate+$48 to clean and Mag test; JUNK.
Set off a daily driven 97 1500 truck that had a 318 and NO symptoms of antifreeze in combustion chamber; JUNK; all cracked in same cylinder. Another set here from a buddys shed; afraid to spend the $$$ for the mag and test.
I am dealing with hughes engines on this mess ("only" 100 miles from me)
Are the "iron Ram" heads the same as EQ ones? Hughes has the Iron Rams that will take the valves, etc from my cracked scrap heads. I have plenty of Magnum rocker gear laying around (factory stock) for the swap.
He told me $321-329 (I don't remember the exact number) I really do not want to spend the money at this time (at least til taxes are figured) but need something and for the money Ive spent I could have BOUGHT 1 of Hughes' "Iron Rams".
As many factory Magnum heads Ive had through my hands that have been cracked (3 of the previous 6 I've had,not counting these 4 that I have at Hughes) it is a dam# wonder that every one of these trucks isn't billowing antifreeze-smelling steam going down the road.
That said; are these cracks superficial/don't mean anything??? and therefore much ado being made about nothing, and that even showing cracks, Magnum heads can be used safely anyway?
Re: SB Magnum head Q's [Re: volaredon] #213364
02/03/09 09:30 PM
02/03/09 09:30 PM
Montana
FuryUs Offline
FuryUs  Offline
Montana
The cracks usually don't go into the cooling passages. As you've found out, there's lots of Magnum engines out there (almost all) running around with cracked heads. Until you pull them and look, ignorance is bliss.
Re: SB Magnum head Q's [Re: FuryUs] #213365
02/03/09 09:34 PM
02/03/09 09:34 PM
ILLINOIS
V
V
ILLINOIS
so from what youre saying I could have them drilled for an LA intake reassemble them and be "good" without a high chance of having a "redo" on my hands?? I hate re dos("come backs") more than about anything.
Re: SB Magnum head Q's [Re: FuryUs] #213366
02/03/09 09:35 PM
02/03/09 09:35 PM
PHOENIX
8T2TOP Offline
8T2TOP  Offline
PHOENIX
SO NONE OF THEM ARE CRACK FREE,LATER ONES HAVE THE SAME PROBLEM? I HAVE A 5.2 '94 205K LOOKING TO UPGRADE TO A 5.9 BUT IF ALL THE STOCK HEADS ARE JUNK WHATS ONE TO DO?
Re: SB Magnum head Q's [Re: 8T2TOP] #213367
02/03/09 09:49 PM
02/03/09 09:49 PM
Land of Lost
flatlinedude Offline
No pulse
No pulse
Land of Lost
Turn your caps lock off and buy a set of better heads.
Carol: "Wow! He's really fast, isn't he?!" John: "Yeah... but he's stupid."
Re: SB Magnum head Q's [Re: volaredon] #213368
02/03/09 10:19 PM
02/03/09 10:19 PM
Land of Lost
No pulse
No pulse
Land of Lost
No one here is going to tell you to run cracked heads... even if it might work. I would never put a motor together with them. I say buy a set of EQ heads, just not from hughes, they're a rip off IMO.
Re: SB Magnum head Q's [Re: flatlinedude] #213369
02/03/09 10:31 PM
02/03/09 10:31 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
Hotroddave40 will..he has in the past without ill effects.
the Hughes Iron Ram ones are enginequest 318A's (mag intake pattern) & 318B's (LA intake pattern). you can find them cheaper than hughes sells, Carolina Machine Engines quoted me complete a year ago with all new parts, 318B's, OEM sized valves, OEM keepers & seals, and GM3100 springs and retainers set up at 1.65IH for $325 ea plus ship.
2017 Grand Cherokee Overland
Re: SB Magnum head Q's [Re: patrick] #213370
02/03/09 11:28 PM
02/03/09 11:28 PM
Ontario, Canada
8
84Stepside Offline
84Stepside  Offline
Ontario, Canada
How bad do these heads crack? can you see them with your eyes of just by magna fluxing? Are they just in the surface or all the way through? I just picked up a 94 5.9 that i am gonna build, was gonna get them checked but i didn't know the problem was this bad.
Re: SB Magnum head Q's [Re: 84Stepside] #213371
02/03/09 11:53 PM
02/03/09 11:53 PM
ILLINOIS
V
V
ILLINOIS
Pretty bad, 7 out of 10 stock mag heads I've had my hands on (and 2 more to check, I'm afraid to find out) so these Iron Rams ARE EQs???
also; considering it cost me $60-some, to send out what wound up to be the only good heads out of the bunch that I've had, when I sold them to someone in NM (that was before I'd had all of them checked out) and I'm not that far from Hughes; would it be better to buy there (I dont mind getting them bare; I have the parts to complete them) instead of paying someone else shipping? And if I get a damaged set shipped in, to deal with that hassle?
Re: SB Magnum head Q's [Re: volaredon] #213372
02/04/09 08:42 AM
02/04/09 08:42 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
yes, the Hughes Iron Rams are enginequests.
and whether or not it's worth it to you to get them from hughes and pay more for a bare head vs. buying them from somewhere else and having them shipped, that's really your call...
on fleabay, there's a place selling them bare for $229 each or another selling them assembled with all new components for $350 each for comparison,if you wanted to see if they're willing to negotiate a price vs. the $329 ea retail price of them.
Re: SB Magnum head Q's [Re: patrick] #213373
02/04/09 09:33 AM
02/04/09 09:33 AM
scratchnfotraction Offline
why cant the machince shop weld and fix them?
I have had a napa machine shop do this for me on some LA 360 heads
maged it,showed me the hair crack in an exhast seat and part of the head
showed me they welded it and machined a new seat in...
cant some of those be fixed?
but then again they could off just blowed smoke and took my $$$
never had a prob with it after that though?
maybe some one can skool me on why it cant be done
Re: SB Magnum head Q's [Re: scratchnfotraction] #213374
02/04/09 11:04 AM
02/04/09 11:04 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
typically these cracks aren't very deep, they don't extend deep enough to hit water and leak...typically. I don't think I'd weld, for a few reasons: 1) unless they ground out significant material, you have no way of knowing if they actually removed all of the crack and if it would begin propogating again, and 2) welding cast iron probably will give you some pretty intense variations in material hardness, from the weld pool to the Heat Affected Zone (HAZ) to the base material. this could make cutting a decent sealing seat very difficult and do some interesting things to seat/valve wear as the engine is run.
since these cracks typically aren't too deep, the proper way to fix the head is to machine out the cracked, cast in valve seats, which usually machines out the cracks, and press in a new hardened steel seat.
IF ALL 16 walve seats are cracked, I'd expect the repair bill to be about the same as the MSRP of a single enginequest head (~$20 per seat max 16 seats)....
something to think about...
Re: SB Magnum head Q's [Re: patrick] #213375
02/04/09 08:27 PM
02/04/09 08:27 PM
ILLINOIS
V
V
ILLINOIS
OK thanks; I asked hughes about that possibility and he said that since they are cracked between the seats that would not "get it all" and don't wanna do it; was it this site where I saw taht someone said that they had 6 BRAND NEW never run OEM heads and 4 had cracks in them????
On your link to EQs for $229; all he has for that $$$ is the "318-A's" (magnum intake pattern) he does not have any 318-B's (LA intake bolts) for that amount; he has exactly 1 set for $30/head more (still cheaper than other places I've checked)
Re: SB Magnum head Q's [Re: volaredon] #213376
02/05/09 06:53 PM
02/05/09 06:53 PM
Austin, Texas
Seank Offline
Seank  Offline
Austin, Texas
If you are doing this from scratch from a good LA I am not sure how much money you save unless you got usable magnum parts aside from the heads (magnum rockers bolts and all of that is about $200 if you have to buy them).
For example, from everything I read you have to change the magnum springs if you have a performance cam. The GM 3100 ones are $135.
The clearwater (ebay)basic 2.02 heads are $350, their super magnum (call them onthe phone, HD springs retainers etc.) are $475 +50 ship. Carolina Machine just quoted me $476 each for the 1.9x size valves plus $60 bucks shipping. 4speed.com I think is about the same price.
So heads shipped are $952 + shipping $50 - 60 = $1012.
Ededbrock LA heads from summit free shipping (12 buck handling charge = sneaky) aluminum LA are $1433+ 12= $1445 shipped. I know its $433 bucks more but I am not sure its worth the conversion hassle if you are not building an engine from scratch. I am sure the edelbrocks have a better resale value as well if you change engines and they are aluminum.
Edelbrock magnums are $1513 ish.
Clearwater, 4 speed, and CME are the only guys I could find on the net selling these.
BTW I am running 340 manifolds so I need remtek gaskets, $40. Its all of this nickle and dime stuff that gets you.
Sean
Re: SB Magnum head Q's [Re: Seank] #213377
02/05/09 08:35 PM
02/05/09 08:35 PM
ILLINOIS
V
V
ILLINOIS
Not to worry; I have plenty of Magnum head gear including a set of '6062 MP springs and the associated retainers; so I dont have to buy them!
