more low end from 440 #213347
02/03/09 08:52 PM
02/03/09 08:52 PM
New York
K
Ken25 Offline OP
Ken25  Offline OP
K
New York
my 440 pulls the hardest from 3-4 grand.its in my 4x4.has b-body 1 3/4 headers,eddy 750, and a holley sd.i'd like to get it to pull harder from 2-3 grand.i have a 67 stock intake i could try.would a 2"ported carb spacer do anything with the sd.i'm in the process of fab. a set of long tube try-y headers.i got my ignition as fast as i safely can. looking for ideas that are on the cheep side. thanks
Re: more low end from 440 [Re: Ken25] #213348
02/03/09 09:00 PM
02/03/09 09:00 PM
Hi Ken. Yes I'd try your stock intake & my(only) (cheep)idea would be to use a 4 hole carb spacer. Not cheep would be a smaller carb.
Re: more low end from 440 [Re: Ken25] #213349
02/03/09 09:10 PM
02/03/09 09:10 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
try the factory intake since you already have it.The SD is a great intake but if you want power from 2000-3000 a dual plane intake will work better.
Re: more low end from 440 [Re: Ken25] #213350
02/03/09 09:24 PM
02/03/09 09:24 PM
Kirkland, Washington
Pacnorthcuda Offline
what cam do you have???
Re: more low end from 440 [Re: Pacnorthcuda] #213351
02/03/09 10:13 PM
02/03/09 10:13 PM
New York
K
Ken25 Offline OP
Ken25  Offline OP
K
New York
stock cam, rv motor
Re: more low end from 440 [Re: Ken25] #213352
02/03/09 11:47 PM
02/03/09 11:47 PM
Central NC
gch Offline
gch  Offline
Central NC
Stock intake will be better where you want it.I would stay away from a carb spacer.The larger plenum will likely move the torque band up.If you have one of the flat low perf stock intakes I would look for a used performer or m1 dual plane.
Re: more low end from 440 [Re: gch] #213353
02/04/09 02:07 AM
02/04/09 02:07 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I think the stock intake will do what you want. The holley SD is a good street/strip intake for a muscle car, not made for use in a truck.
Re: more low end from 440 [Re: DaytonaTurbo] #213354
02/04/09 08:52 AM
02/04/09 08:52 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
another thing you could do is actually take the water pump and t-chain cover off, and get one of those kits with the offset bushings and advance the cam 2-4 degrees.
2017 Grand Cherokee Overland
