Re: A-833 overdrive
[Re: johnfin]
#2132942
08/14/16 09:15 PM
08/14/16 09:15 PM
Posts: 12,078 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Have put several in over the years. They work good if you have low rear gears and don't beat on it too hard. I always thought the 833OD worked best in front of 3.91s or lower. 3.55s and higher I didn't care for.
Master, again and still
Re: A-833 overdrive
[Re: johnfin]
#2132983
08/14/16 09:56 PM
08/14/16 09:56 PM
Posts: 1,511 AZ
Mike P
AZ
I had one (aluminum case) in my 57 while I had the Iron Case 833OD out being rebuilt. I was always afraid to beat on it too hard. I've come across a couple of cracked aluminum cases over the years which makes me a little leery of them. The iron case has seen it's fair share of abuse.
I agree with Dave on the 3.91 or lower (I'm running 4.10s in the Plymouth). With 3.55s or higher you really notice the gear split between 2nd and 3rd. With the lower gears 1st gear winds up almost too quickly but for every day driving it's a great transmission, especially if you're running a cam that's low end torque impaired.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
Re: A-833 overdrive
[Re: Kern Dog]
#2133177
08/15/16 01:00 AM
08/15/16 01:00 AM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
. I did not like the wide gear spacing. 3.09 1st, 1.67 second? Really I don't like it either. Not sure why so many people are okay with this. This is the exact reason cars and trucks from today have at least 6 gears.
Re: A-833 overdrive
[Re: johnfin]
#2133269
08/15/16 03:41 AM
08/15/16 03:41 AM
Posts: 43,174 Bend,OR USA
Cab_Burge
I have one in my 1966 Dodge Coronet Deluxe two door sedan that I'm putting together now, 440 with 3.91 stroke, Eddy RPM heads on pump gas, Dana 60 with 3.54 gears and 275x60x15 inch tires on the back I have several of them, I will not beat hard on this tranny, not EVER This tranny came out of a truck or van with the dual tranny mounts, I took the side cover off of it to inspect it before deciding to use it, it looks good so I'm going to try it Hopefully it will do good
Re: A-833 overdrive
[Re: Magnum]
#2133313
08/15/16 08:40 AM
08/15/16 08:40 AM
Posts: 1,229 In The Hills
jughed
In The Hills
I put an iron case OD 4 speed in the Dart years ago. The 440 couldn't hurt the trans, and it did make the 4.10 rear gears seem like 3.55s, but that rpm drop when shifting to 2nd killed the deal. OP, if you're set on using an OD and your only concern is the alum case holding up, get an iron case OD instead. (i have one for sale ).
Re: A-833 overdrive
[Re: johnfin]
#2133388
08/15/16 11:44 AM
08/15/16 11:44 AM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I had one behind the TT440. The OD was great with the 3.23 gears but I really did not like the 1-2 split.
Re: A-833 overdrive
[Re: 65rbdodge]
#2133402
08/15/16 11:57 AM
08/15/16 11:57 AM
Posts: 863 Pinelands , NJ
joelson6
Pinelands , NJ
I have one in my street rod behind a 318 and it has 323 gears. its built for comfort not for speed. It works great and I'm happy with it, I really like cruising 65mph at 2100rpms. I really don't notice the big jump in ratios between shifts. this was my thought too. these trans' were designed for highway cruising. why is everyone trying to use them as a performance trans when it's clearly not designed for that.
Re: A-833 overdrive
[Re: joelson6]
#2133524
08/15/16 02:26 PM
08/15/16 02:26 PM
Cab_Burge
I have one in my street rod behind a 318 and it has 323 gears. its built for comfort not for speed. It works great and I'm happy with it, I really like cruising 65mph at 2100rpms. I really don't notice the big jump in ratios between shifts. this was my thought too. these trans' were designed for highway cruising. why is everyone trying to use them as a performance trans when it's clearly not designed for that. You know how hot rodders are, if you ain't testing different parts your not learning On my deal it is a street car, not a Pro Street wannabe race car
Re: A-833 overdrive
[Re: Magnum]
#2134086
08/16/16 02:08 AM
08/16/16 02:08 AM
RapidRobert
. I did not like the wide gear spacing. 3.09 1st, 1.67 second? Really I don't like it either. Not sure why so many people are okay with this. This is the exact reason cars and trucks from today have at least 6 gears. agreed, I had one in a mild build & it was unacceptable (that split)
Re: A-833 overdrive
[Re: joelson6]
#2134746
08/16/16 10:27 PM
08/16/16 10:27 PM
Cab_Burge
Isn't the ratio on the NP 833 O.D. in 1st,2nd and 3rd gear the same as the 3 speeds in stock Mopars? I seem to remember seeing all the gear ratio in a old Borg Warner catalog showing them the same Not that I'm saying I like those ratios, I had one 1973 340 Duster with the original 3 speed that I ended up swapping it for a standard 1969 A body NP 833 That made that car easier to sell
