which s/s leaf springs to use on a 64 stick car?
#2132855
08/14/16 07:39 PM
08/14/16 07:39 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
i have a 64 fury that needs new s/s springs. car is street strip, which springs are best to get that will handle 600+hp?
Hell Hath No Fury Like Mine
Re: which s/s leaf springs to use on a 64 stick car?
[Re: sixpacksteve]
#2132876
08/14/16 08:05 PM
08/14/16 08:05 PM
Posts: 4,724 Moved to N.E. Tennessee
GomangoCuda
Manual Trans and 600hp will want 002/003 ss springs and appropriate hangers. OR Caltracs and monoleafs.
[Re: GomangoCuda]
#2132912
08/14/16 08:35 PM
08/14/16 08:35 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
which are the appropriate hangers?
[Re: sixpacksteve]
#2132923
08/14/16 08:50 PM
08/14/16 08:50 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
I bolt mine directly to the factory spring hangers and I have no issues at all. I have thought about the 002,003 springs but with my car weight I would think the rear would sag very quickly given the reputation of the current MP SS springs. The 454,455 springs have a very stiff front segment which is what you want under a stick car with some decent low end grunt Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: sixpacksteve]
#2132926
08/14/16 08:53 PM
08/14/16 08:53 PM
Posts: 31,044 Oregon
AndyF
[Re: AndyF]
#2132959
08/14/16 09:32 PM
08/14/16 09:32 PM
Posts: 1,675 Mi.
G-Money1320
Mi.
002-003 are for 3000# cars which would be underrated for a heavier car like yours. I have a set of 865-866 for E-bodies which are for 3400# cars so those would maybe the least you would want to put on. Gus has the setup like you are looking for. Good Luck!
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out. 11.06 open headers----so far!!
[Re: G-Money1320]
#2132994
08/14/16 10:07 PM
08/14/16 10:07 PM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
002-003 are for 3000# cars which would be underrated for a heavier car like yours. I have a set of 865-866 for E-bodies which are for 3400# cars so those would maybe the least you would want to put on. Gus has the setup like you are looking for. Good Luck! I have 002/003's on for well over 10 years. Absolutely no issues. I run 1 3/4" lowering blocks for obvious reasons. Car weight with me in it is over 3900#. Street/strip car with Rancho's on back and OE torsion bars up front with CE 90/10's. NO SNUBBER.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
[Re: 68LAR]
#2133161
08/15/16 12:27 AM
08/15/16 12:27 AM
fourgearsavoy
Rittman Ohio
Larry I didn't even want to order the 002,003's because I thought they would go flat like MP springs tend to do but I can sure see they work for you I drive my car to the track with all my camping gear and equipment in the trunk for weekend races so I went with the heavy springs. Gus
[Re: fourgearsavoy]
#2133198
08/15/16 01:34 AM
08/15/16 01:34 AM
68LAR
South Park, Pa.
Larry I didn't even want to order the 002,003's because I thought they would go flat like MP springs tend to do but I can sure see they work for you I drive my car to the track with all my camping gear and equipment in the trunk for weekend races so I went with the heavy springs. Gus Gus, I truly believe that mine have lasted so long without sagging, is because over the winter months when I do preventive maintenance on the car, I have it on jack stands so the suspension hangs. (no weight on the springs at all). I do this each and every year. A few years back I was doing the "driving the car to the track routine" I would load up the slicks in the trunk and back seat along with tools and jack. As I got older, I said the heck with this and bought a trailer. Much easier on my old body....
[Re: G-Money1320]
#2133461
08/15/16 12:55 PM
08/15/16 12:55 PM
Posts: 11,713 Portage,michigan
B3422W5
Portage,michigan
002-003 are for 3000# cars which would be underrated for a heavier car like yours. I have a set of 865-866 for E-bodies which are for 3400# cars so those would maybe the least you would want to put on. Gus has the setup like you are looking for. Good Luck! 002/003( the same set) have been under my old Blue Duster for almost twenty years now. Weighed 3350 when I had it, 3220 now. No sagging at all. Car has been as quick as 9.60's at 140 with them recently. My current Duster weighs 3415 with me and a full tank of gas( how I always race it) and actually has more rake than I want. The 002/003's on it for the last 3 years were on another car for years before I bought them.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: sixpacksteve]
#2133553
08/15/16 02:56 PM
08/15/16 02:56 PM
Posts: 1,481 Outside
thedriver
Outside
I got a spare set of 454/455 springs I'd give ya if you were 2000miles closer
1973 challenger Dana. 4 speed. Low deck.
[Re: sixpacksteve]
#2133557
08/15/16 03:00 PM
08/15/16 03:00 PM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
Had the 002 and 003 on the 65.They were low new.I even had them rearched and not much better.Went with the 3800 ones and no problems.Use Andys hangers as the MP one are wrong.Early B bodys had a 21 inch frt segment SS are 20 inch.Rocky
Chrysler Firepower
[Re: therocks]
#2133679
08/15/16 05:50 PM
08/15/16 05:50 PM
fourgearsavoy
Rittman Ohio
Had the 002 and 003 on the 65.They were low new.I even had them rearched and not much better.Went with the 3800 ones and no problems.Use Andys hangers as the MP one are wrong.Early B bodys had a 21 inch frt segment SS are 20 inch.Rocky Rocky I got me one of them altered wheelbase cars,it's one inch shorter seriously though I just tried them without the correct hanger and my tires cleared with room to spare.Since I was getting a custom driveshaft for the Richmond I just left them that way. Gus
[Re: fullmetaljacket]
#2133866
08/15/16 09:37 PM
08/15/16 09:37 PM
fourgearsavoy
Rittman Ohio
Lee I thought about that and figured one inch forward couldn't hurt I'm really not on the "razors edge" of a chassis tune.I'm just happy being an ET chaser that is just out there to whoop on my car all the way out the back door. When I have slicks on it it hits pretty hard but the ET Streets tend to spin at the hit which is probably a good thing because I have heard the weak link on a Richmond is first gear. Gus
[Re: sixpacksteve]
#2133890
08/15/16 10:23 PM
08/15/16 10:23 PM
therocks
Niles , Ohio
Gus i thought about using my OE hangers.I would have had to make a new drive shaft.Often thought about when I move inboard to have the hangers drilled for 22 inch and use new style springs.i can go to Emch Spring here and have just about anything I want made.Rocky
Chrysler Firepower
[Re: 68LAR]
#2134084
08/16/16 02:04 AM
08/16/16 02:04 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Larry I didn't even want to order the 002,003's because I thought they would go flat like MP springs tend to do but I can sure see they work for you I drive my car to the track with all my camping gear and equipment in the trunk for weekend races so I went with the heavy springs. Gus Gus, I truly believe that mine have lasted so long without sagging, is because over the winter months when I do preventive maintenance on the car, I have it on jack stands so the suspension hangs. (no weight on the springs at all). I do this each and every year. A few years back I was doing the "driving the car to the track routine" I would load up the slicks in the trunk and back seat along with tools and jack. As I got older, I said the heck with this and bought a trailer. Much easier on my old body.... Larry you should do like I do and just drive the slicks on the street and to the track. I love it as all I do is lower the tire pressure when I get to the track. And when many are crawling under their trailers tieing their cars down this old man just puts some air back in my tires and drives home. I have alot of knee and back problems and its tuff for me to try and crawl under a trailer anymore so this works good for me. But I do understand why a person who races alot needs a trailer. Ron
