Re: What's different 70-71 vs 72-74 Wiper motors [Re: moparmarks] #1142775
12/30/11 01:57 PM
12/30/11 01:57 PM
Valencia, España
NachoRT74 Online content
NachoRT74  Online Content
Valencia, España
MaMopar made everything in misterious ways LOL
Re: What's different 70-71 vs 72-74 Wiper motors [Re: BDW] #2132155
08/13/16 07:17 PM
08/13/16 07:17 PM
VT
Mike Roberge Offline
VT
Can I use a readily available 2 speed ’72 Charger wiper motor to replace my near impossible to find 2 speed ’71 Charger wiper motor?
*I realize I could get my ’71 2 speed motor restored/repaired, but all I’m looking for is a basic parts store price and quality
*The ’72 wiper motor looks the same as my ‘71, but I am aware that the ’71 B body uses wiper crank/pin arm 2822290, whereas the ’72 Charger uses wiper crank/pin arm 3431553
When I look at pictures online of these two crank arms, they look virtually the same?
So my question is: will I be able to use/mount my 2822290 crank arm on the ’72 motor?
Michael Roberge '71 Charger R/T 440 4bbl, 500HP/500Ftlb Best ET: 11.590 120MPH
Re: What's different 70-71 vs 72-74 Wiper motors [Re: BDW] #2132398
08/14/16 01:00 AM
08/14/16 01:00 AM
BDW Offline OP
BDW  Offline OP
Old post, but I ended up buying the 73 motor and it bolted up fine and is still working.
From memory the only difference was the size of the slot for the crank arm. I seem to remember the newer motor had a smaller shaft size (flat part). I cut a small shim and added it, but I honestly don't think it was needed.
Buy it local and try, if it doesn't work you can return it.
Re: What's different 70-71 vs 72-74 Wiper motors [Re: BDW] #2132522
08/14/16 09:31 AM
08/14/16 09:31 AM
VT
VT
cnxt,
Thanks for the info. My local parts store has one coming this week. It is a A1-Cardone re-manufactured unit, part# 40-382. It crosses to ’72 Charger.
*After looking more closely at the 71 vs 72 crank arms – I agree- they look just slightly different, but nothing that a small modification (aka: like you mentioned: a possible shim) would make working fit.
I will post an update, after I try this conversion.
Thanks,
-miker71
* Attached pics: photos of the ’71 (2822290) and ’72 (3431553) crank arms *
Re: What's different 70-71 vs 72-74 Wiper motors [Re: BDW] #2153580
09/13/16 11:14 AM
09/13/16 11:14 AM
VT
VT
Update for ’70 & ‘71 E-body, and ’71 B-body 2-Speed Wiper motor replacement:
Like cnxt said, the readily available/affordable parts store ’72 Charger(’73 Challenger) wiper motor is a direct bolt in and the ’71 linkage crank arm will bolt up, but is a bit loose due to the ’72 motor has a smaller shaft.
For me, this resulted in sloppy wiper action: The wipers wouldn’t cover as much windshield, and the would not park properly(wouldn’t hide away completely) – due to the slop.
Also, the ’72 motor shaft Parks/stops in a slightly different position (*this probably also attributes to not parking in the correct position).
Upon further investigation I found out the ’72 Crank arm motor shaft rectangular cutout is at a different angle than the ’71 Crank arm.
So, I purchased a ’72 crank arm(pt#3431553) on eBay to go on my ’72 motor. It fits perfectly w/no slop. Now my wipers work perfectly and park perfectly, - like brand new!
