Re: Advice on Choosing a Musclecar Oil
[Re: b_body_fan]
#2132055
08/13/16 04:27 PM
08/13/16 04:27 PM
Posts: 15,552 Norwich CT USA
moparts
Norwich CT USA
All the muscle / racing oils are way over priced
That is why I switched to 15-40 Rotella Diesel Oil in all my flat tappet cars. Still have what is needed to lube up the cam.
Cheap and by the gallon
Tom ,
2011 Ram 3500 C&C Diesel 2009 Challenger R/T 1971 Challenger Conv. 511/4 speed 1970 Challenger R/T 503/727
[Re: moparts]
#2132071
08/13/16 04:52 PM
08/13/16 04:52 PM
Posts: 15,496 Omaha Ne
TJP
Omaha Ne
Cheap and by the gallon FYI, Rumor had it a few years back that again due to emissions etc. on Diesels the ZDDP content in Rotella was being reduced. You may want to check into the validity of that claim with Rotella.
[Re: frank]
#2132098
08/13/16 05:42 PM
08/13/16 05:42 PM
Posts: 6,224 JERSEY
RJS
JERSEY
Brad Penn is what I put in my cars. Any performance/hot rod shop should carry it. Its on the shelf where I live. You don't need to add anything to this oil; just pour it in. Yep I use Brad Penn 20W 50 $7 a quart but does the job without worrying. Years back I used Rottella but never liked how it looked when doing a change. Isn't as good as it used to be for our car's. Ron
[Re: RJS]
#2132131
08/13/16 06:42 PM
08/13/16 06:42 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Brad Penn is what I put in my cars. Any performance/hot rod shop should carry it. Its on the shelf where I live. You don't need to add anything to this oil; just pour it in. Yep I use Brad Penn 20W 50 $7 a quart but does the job without worrying. Years back I used Rottella but never liked how it looked when doing a change. Isn't as good as it used to be for our car's. Ron And no additive needed !
[Re: b_body_fan]
#2132160
08/13/16 07:24 PM
08/13/16 07:24 PM
Posts: 17,862 albany ny
05dakota
albany ny
no reason brad penn should cost that much
5549 post on old board
[Re: moparts]
#2132247
08/13/16 09:48 PM
08/13/16 09:48 PM
Posts: 10,556 Rittman Ohio
fourgearsavoy
Rittman Ohio
I look at it this way, how often do you change the oil in your hotrod? Most of us it's once a year so what's $50 for something as important as good oil in a flat tappet cam engine I use Brad Penn for my engine on the advice of of some knowledgeable engine builders. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#2132638
08/14/16 01:37 PM
08/14/16 01:37 PM
Posts: 4,952 northwest USA
NANKET
northwest USA
I look at it this way, how often do you change the oil in your hotrod? Most of us it's once a year so what's $50 for something as important as good oil in a flat tappet cam engine I use Brad Penn for my engine on the advice of of some knowledgeable engine builders. Gus Good info here. My engine machinist also races a SC dragster. His oil recommendation for street cars is Joe Gibbs or Brad Penn. This is your choice. How soon do you want to repair your engine that is otherwise fine?
[Re: b_body_fan]
#2132688
08/14/16 03:02 PM
08/14/16 03:02 PM
Posts: 16,161 Mesa, Arizona
dart4forte
Mesa, Arizona
Rotello 15/40 with a little ZDDP added
Abe Lincoln
