Re: Tubing benders
[Re: MR_P_BODY]
#2131024
08/12/16 12:38 PM
08/12/16 12:38 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
I used Milwaukee hole saws in my notcher.. also for degrees I got this big yellow protractor from HF... fit perfect on the center and when the tube started to bend I would zero it then That's what it looks like! !!! LOL... I assume you havent even assembled it yet No but I'm thinking I should this weekend to see how it works. Stay tuned I may need you advice!. Lol Matt
Re: Tubing benders
[Re: sgcuda]
#2131166
08/12/16 03:09 PM
08/12/16 03:09 PM
Posts: 11,714 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I used the Sawzall on some tubing that was already welded in place. Didn't work at all. Was using DeWalt 18T bimetal blades. Tooth the teeth off faster than I could change the blades. That's why I was asking about the holesaw. I might have attacked the tubing with too fast a rate of speed, like you mentioned. Will try some practice cuts with some 24T blades. I got involved in some upgrades to a homebuilt cage a number of years ago, was supposed to be 4130 and had been certified as such, and it was an older car then. The tubing in that car was unbelievably hard and I had the same issue. Was terrible to work on. Don't know what it was, but it wasn't Cond "N" 4130.
Re: Tubing benders
[Re: CMcAllister]
#2131434
08/12/16 08:36 PM
08/12/16 08:36 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
This is one of the better threads in awhile! Thanks for sharing ideas and to others thanks for entertaining me.
I too have a JD2 bender mounted on a square tube drop in receiver that we use for a number of other tools also. Just another mounting idea.
I am a electrician and bend alot of conduit. Most of the time with a Greenlee 882 hyd. bender, I found that Mittlers shoes also fit the 882 bender and make very nice bends in thin moly tube, with no drama.
"Just a Bracket car dressed up like a streetcar"
Re: Tubing benders
[Re: Monte_Smith]
#2131555
08/12/16 10:38 PM
08/12/16 10:38 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Let me save you some time on the windshield bars. Don't worry about going from main hoop all the way to floor. Go to a dash bar and make the a pillar bars two pieces So, are you saying I can just use a couple of uprights from the frame to the dash level, have a dash cross brace, and then attach from the main hoop to the cross brace in line with the uprights? Is that legal? Never thought of that. Would you have a pic of this setup for clarification? Thanks, Monte.
[image][/image]
Re: Tubing benders
[Re: Just-a-dart]
#2131562
08/12/16 10:42 PM
08/12/16 10:42 PM
sgcuda
Just A Dart. That's another great idea. I can weld up a mounting perch on the receiver of my truck. Wouldn't have to drill holes in the garage floor or worry about having enough room. Just have to make sure I don't do what my kid did to my truck with the couch that didn't quite fit in the bed. Ya-da, ya-da, ya-da... I can get a new rear sliding window for $250 installed.
[image][/image]
Re: Tubing benders
[Re: sgcuda]
#2131574
08/12/16 10:52 PM
08/12/16 10:52 PM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
The Fabricator series on You Tube is very helpful, the guy lays things out clearly and breaks it down well. I've been seriously thinking about getting a bender for myself and since need and finances are a ways off, I'll be soaking up as much as I can and ignore the
Re: Tubing benders
[Re: sgcuda]
#2131688
08/13/16 01:06 AM
08/13/16 01:06 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Let me save you some time on the windshield bars. Don't worry about going from main hoop all the way to floor. Go to a dash bar and make the a pillar bars two pieces So, are you saying I can just use a couple of uprights from the frame to the dash level, have a dash cross brace, and then attach from the main hoop to the cross brace in line with the uprights? Is that legal? Never thought of that. Would you have a pic of this setup for clarification? Thanks, Monte. Of course it's legal. There is nothing that says the A-pillar bars have to be one piece from main hoop, down by dash and to floor, with dash bar welded between those. Some do it that way, some run halo bars, just depends on the car. What I have done on some cars with stock firewalls, is actually weld the dash bar to the back of firewall and in between plates in the front jamb area. This gets the dash bar forward and out of the way. The lower supports weld to bottom of dash bar and can go straight down, angle back, just wherever they need to. Then the A-pillar bar comes from hoop, down through dash and lands on dash bar. Eliminates some bends and makes it much easier.........Hard to tell, but pic below MAY be done like that. If not, just imagine this dash bar welded in first and the others coming to it. This way you put the dash bar wherever you WANT it, not where it is convenient to weld it between bars when done the other way
Re: Tubing benders
[Re: Monte_Smith]
#2131818
08/13/16 10:19 AM
08/13/16 10:19 AM
Posts: 19,633 north of coder
moparx
you guys would laugh yourselves silly at my bender. due to my particular circumstances, and since i have modest fab skills, i built my bender using a couple of those cheapy plans you see offered in different places. after studying those plans and looking at several pro benders both in person and picture form, it took me a couple of months to come up with a workable tool that fit my needs and did a great job. i made a 1 3/4" and a 1 5/8" set of dies as well. the bends came out perfect with no dimples or crush, and that surprised me because i had to guess on the clearances needed to free the tube after bending. i only had one project to do [my 33 dodge humpback panel] and it was just mild steel, so it worked as intended and wasn't that hard to use even with just a 16ton, long ram bottle jack as power. since that time, i experimented with adapting my dies to smaller diameter tube sizes using the spacer method shown, and that worked well also. at my age, i won't be building cages for a living, although from time to time, this contraption is broke out to make a couple of pickup push bars and a riding tractor head bar. worked good for those projects as well. a "muscle" machine might be ok for a one time project, but if a guy was thinking to bend tube on a regular basis, a "power adder" supplement would be the only way to fly, as well as several of other previously mentioned must have features.
Re: Tubing benders
[Re: Skeptic]
#2132633
08/14/16 01:29 PM
08/14/16 01:29 PM
MattW
Ontario Canada
The Fabricator series on You Tube is very helpful, the guy lays things out clearly and breaks it down well. I've been seriously thinking about getting a bender for myself and since need and finances are a ways off, I'll be soaking up as much as I can and ignore the Thanks for the link! Very helpful!
Re: Tubing benders
[Re: sgcuda]
#2140324
08/24/16 11:47 PM
08/24/16 11:47 PM
sgcuda
Quicktree gave me a great deal on his Pro-Tool tubing bender. Has 5 dies from 1" up to 1 3/4", software and a tubing notcher. Really top notch looking stuff and Made in USA. Now to set it up and start playing. Thanks again, Quicktree.
[image][/image]
Re: Tubing benders
[Re: sgcuda]
#2140938
08/25/16 10:47 PM
08/25/16 10:47 PM
sgcuda
Thanks, Mr P. That's what I was thinking, but wasn't sure. The old stuff on the dies seems pretty slick and tacky. Seems like it would be a PITA for cleanup.
[image][/image]
Re: Tubing benders
[Re: sgcuda]
#2141955
08/27/16 03:55 PM
08/27/16 03:55 PM
Quicktree
Quicktree gave me a great deal on his Pro-Tool tubing bender. Has 5 dies from 1" up to 1 3/4", software and a tubing notcher. Really top notch looking stuff and Made in USA. Now to set it up and start playing. Thanks again, Quicktree. no problem, glad it will get some use. I think I bent maybe 3-4 bends with it. good luck with your build.
Re: Tubing benders
[Re: MR_P_BODY]
#2141959
08/27/16 03:57 PM
08/27/16 03:57 PM
Quicktree
I just used cheap wheel bearing grease with a brush that's what I used, that is whats on the die, just been setting up for a while.
Re: Tubing benders
[Re: Quicktree]
#2142018
08/27/16 05:40 PM
08/27/16 05:40 PM
Posts: 8,350 fredericksburg,va
cudaman1969
fredericksburg,va
I just used cheap wheel bearing grease with a brush that's what I used, that is whats on the die, just been setting up for a while. I hope you mean lube just the pins, instructions on my JD 32 said to never use lubricants on the forming dies groove, the tube will tend to slip backwards if used.
Re: Tubing benders
[Re: cudaman1969]
#2142019
08/27/16 05:51 PM
08/27/16 05:51 PM
Quicktree
I just used cheap wheel bearing grease with a brush that's what I used, that is whats on the die, just been setting up for a while. I hope you mean lube just the pins, instructions on my JD 32 said to never use lubricants on the forming dies groove, the tube will tend to slip backwards if used. don't know nothing about the JD 32, I watched a friend who has bending tube for a long time he used grease on the die. mine never slipped.
