Cosmetic or composite head gasket with 11.5:1 comp? pics add #2131269
08/12/16 05:07 PM
08/12/16 05:07 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
I'm not real impressed with the shop that machined my block. Didn't fit the cam, didn't install oil shaft bushing and I don't like how they decked it. I told them 0 deck, so they take .002 off one side and .010 off the other to get 0 deck, but they left what looks like rust in the deck. It's smooth to the touch, but not sure it will seal a cometic. Can I use a composite gasket with 11.5:1 on a 511? I'll get some pics later. pics added
Re: Cosmetic or composite head gasket with 11.5:1 comp? [Re: mopar dave] #2131299
08/12/16 05:44 PM
08/12/16 05:44 PM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
No need IMO 1009's should do just fine.
Re: Cosmetic or composite head gasket with 11.5:1 comp? [Re: mopar dave] #2131322
08/12/16 06:23 PM
08/12/16 06:23 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
IMO, 1009's are not even an option on a 400 block.
If I were putting together it would get cometics.
Re: Cosmetic or composite head gasket with 11.5:1 comp? [Re: fast68plymouth] #2131326
08/12/16 06:33 PM
08/12/16 06:33 PM
Columbus, Ohio
Columbus, Ohio
Sorry Small block guy here, I thought all BB RB stuff was the same.
Re: Cosmetic or composite head gasket with 11.5:1 comp? [Re: mopar dave] #2131327
08/12/16 06:39 PM
08/12/16 06:39 PM
So. Burlington, Vt.
So. Burlington, Vt.
In theory they would work, but they often have the fire ring land on the edge, or just off the edge of the bore chamfer.
If they are like that, the wire gets pushed down into the bore, the combustion gasses get behind the fire ring and torch the gasket..... And then usually the head and block.
I have repaired several motors where this happened with 1009's.
Re: Cosmetic or composite head gasket with 11.5:1 comp? [Re: fast68plymouth] #2131333
08/12/16 06:58 PM
08/12/16 06:58 PM
Mt Morris Michigan
Mt Morris Michigan
OK, cometics. Should I spray block side of gasket with copper?
Re: Cosmetic or composite head gasket with 11.5:1 comp? [Re: mopar dave] #2131341
08/12/16 07:05 PM
08/12/16 07:05 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
I'm at 11:6:1 on my 512/400 block build w/Eddy heads. Its been running Mr Gasket MRG-3247G for 2 yrs now. No issues.
Ok
Re: Cosmetic or composite head gasket with 11.5:1 comp? [Re: mopar dave] #2131358
08/12/16 07:19 PM
08/12/16 07:19 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Here are some answers for you. Just click on the link.
http://www.cometic.com/ft-2800-technical-support.html
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Cosmetic or composite head gasket with 11.5:1 comp? [Re: pittsburghracer] #2131360
08/12/16 07:21 PM
08/12/16 07:21 PM
PA.
"Little"John
"Little"John
PA.
Here's a good place to order them from
http://www.4secondsflat.com/Cometic-MLS_Gaskets.html
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Cosmetic or composite head gasket with 11.5:1 comp? [Re: mopar dave] #2131363
08/12/16 07:21 PM
08/12/16 07:21 PM
Cab_Burge Online work
Cab_Burge  Online Work
I've used a bunch of the good old standard over the counter Fel Pro blue composite head gaskets on motors with more compression than yours, no spray of any kind either work If you doubt that the deck is smooth enough for Cometics, smoother than 50RA, then don't take a chance on them twocents
Re: Cosmetic or composite head gasket with 11.5:1 comp? [Re: Cab_Burge] #2131418
08/12/16 08:17 PM
08/12/16 08:17 PM
Mt Morris Michigan
Mt Morris Michigan
I don't know what 50RA is.
Re: Cosmetic or composite head gasket with 11.5:1 comp? [Re: pittsburghracer] #2131420
08/12/16 08:18 PM
08/12/16 08:18 PM
Mt Morris Michigan
Mt Morris Michigan
Thanks for the link.
Re: Cosmetic or composite head gasket with 11.5:1 comp? [Re: mopar dave] #2131426
08/12/16 08:27 PM
08/12/16 08:27 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I'm not real impressed with the shop that machined my block. Didn't fit the cam, didn't install oil shaft bushing and I don't like how they decked it. I told them 0 deck, so they take .002 off one side and .010 off the other to get 0 deck, but they left what looks like rust in the deck. It's smooth to the touch, but not sure it will seal a cosmetic. Can I use a cometic gasket with 11.5:1 on a 511? I'll get some pics later
17059 Marine gaskets............
Re: Cosmetic or composite head gasket with 11.5:1 comp? [Re: Thumperdart] #2131481
08/12/16 09:28 PM
08/12/16 09:28 PM
Mt Morris Michigan
Mt Morris Michigan
Thanks Dom. I will check those.
Re: Cosmetic or composite head gasket with 11.5:1 comp? [Re: mopar dave] #2131563
08/12/16 10:42 PM
08/12/16 10:42 PM
dogdays Offline
dogdays  Offline
I'm still imagining the Cover Girl cosmetic head gaskets!
R.
Re: Cosmetic or composite head gasket with 11.5:1 comp? [Re: mopar dave] #2131565
08/12/16 10:44 PM
08/12/16 10:44 PM
AndyF Offline
AndyF  Offline
Aluminum heads correct? I won't use anything other than Cometic gaskets if I'm running aluminum heads. The composite gaskets will brinell the head. Not necessarily a problem if you put the engine together once and leave it together, but I got tired of having the heads resurfaced each time I pulled them off. So Cometic gaskets save me money in the long run.
Re: Cosmetic or composite head gasket with 11.5:1 comp? [Re: AndyF] #2131575
08/12/16 10:52 PM
08/12/16 10:52 PM
PA.
"Little"John
"Little"John
PA.
Plus they are re-usable. I finally installed my first set on my 422 after my 1009's blew into the intake valley. They are also going on the 512 and 572 I am building too
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Cosmetic or composite head gasket with 11.5:1 comp? [Re: dogdays] #2131630
08/12/16 11:51 PM
08/12/16 11:51 PM
Mt Morris Michigan
Mt Morris Michigan
Cool,huh. Spell check sucks
Re: Cosmetic or composite head gasket with 11.5:1 comp? [Re: mopar dave] #2131641
08/13/16 12:00 AM
08/13/16 12:00 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Fel-Pro's started to fail on my 505 shortly after I got it together. Not sure of the probelem, but went back with Cometic and trouble free since.
'63 Dodge 330
11.19 @ 121 mph
Re: Cosmetic or composite head gasket with 11.5:1 comp? [Re: mopar dave] #2131642
08/13/16 12:01 AM
08/13/16 12:01 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Dave, go for it, 1009's, spray em with copper and fit them wet. Will be fine unless you are going on the bottle.
1963 Plymouth Max Wedge
1971 Barracuda
