Nag1 Manual Valve body? #2115928
07/23/16 12:41 AM
07/23/16 12:41 AM
USA
hudsonhornet7x Offline OP
USA
I know that the nag can be a pain because of all the electronics. Does anyone make a manual valve body to eliminate the headache? Is this even possible with this type of tranny?
Re: Nag1 Manual Valve body? [Re: hudsonhornet7x] #2115989
07/23/16 05:15 AM
07/23/16 05:15 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Have not heard of such an animal. They have TCM's with like 6800 rpm shift points though. After a certain point they get ditched in favor of Rosslers.
Mopar to the bone!!!
Re: Nag1 Manual Valve body? [Re: hudsonhornet7x] #2116384
07/23/16 11:09 PM
07/23/16 11:09 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
You need to talk to Builder Bill from Paramount Performance. I was involved with his Jeep when he was building the first trans brake valve bodies available. He has done some amazing things with Nags over the years.
[image][/image]
Re: Nag1 Manual Valve body? [Re: sgcuda] #2131307
08/12/16 05:54 PM
08/12/16 05:54 PM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
You can also clip the torque intervention wire and put in on a rocker switch, will not set a DTC and will give it a shift kit type feel. cannot remember the wire color, but it will prevent HP decrease that happens via TCM/PCM during shift event.
Re: Nag1 Manual Valve body? [Re: hudsonhornet7x] #2307631
05/19/17 10:02 PM
05/19/17 10:02 PM
USA
USA
Bumping this to see if there have been any developments with a manual valve body. Sure would be nice to put in a nag1 without the extra wiring and computer.
