Vinyl top pros and cons? #2131062
08/12/16 01:26 PM
08/12/16 01:26 PM
an8sec70cuda Online content OP
an8sec70cuda  Online Content OP
My cuda left the factory w/ a black vinyl top, but it had already been removed when I got it, holes for the trim filled in, etc. I'm pretty sure I have the trim for it...came w/ the car when I bought it.
I am considering putting a black vinyl top back on it when I redo the body and paint in the future. Now, this car is not original at all and never will be (was originally Go Mango, now it's B5), I just kinda like the look of the vinyl tops. The car will most likely remain B5 blue.
I've never had a car w/ a vinyl top and wondering what the pros and cons are? Any reason to leave it a hardtop? shruggy
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Vinyl top pros and cons? [Re: an8sec70cuda] #2131065
08/12/16 01:31 PM
08/12/16 01:31 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
they can cause rust problems, that cuda looks AWESOME like it is.
Re: Vinyl top pros and cons? [Re: an8sec70cuda] #2131070
08/12/16 01:35 PM
08/12/16 01:35 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Top dressing on the paint looks bad, wax and polish on a vinyl top looks bad. Basically it makes more work cleaning & detailing the car.
Re: Vinyl top pros and cons? [Re: CSK] #2131077
08/12/16 01:43 PM
08/12/16 01:43 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
Unless you are going to keep the car outside for an extended period of time (years), or in a damp environment, getting rust under your vinyl top is very unlikely to be a problem for you.
It's all a matter of personal taste. If you like the look, or are restoring a car to the tag on a car that was built with a vinyl top, go for it! If you prefer no top, that's cool too.
I have a friend who has a red Challenger T/A with a black interior that was originally built with a white vinyl top. He has owned the car almost 40 years and removed the top shortly after he bought it. Restored it a few years ago and did not put a vinyl top back on it. Lots of us give him a hard time, who has ever seen a red T/A with a white top? Super rare! But he hated the look and kept the trim for if he sells it some day and the buyer wants to return it to how it was built by putting a top back on it. So that's cool, all a matter of the owners taste!
Re: Vinyl top pros and cons? [Re: an8sec70cuda] #2131090
08/12/16 01:58 PM
08/12/16 01:58 PM
The car is definitely not parked outside. I do have the fender tag and a lot of the original stuff for the car, but the original 340 and 727 are LONG GONE. The original owner scrapped the 340 when it blew a head gasket and gouged the deck surface back in the '70s....probably made a couple Hondas out of it by now. No idea where the 727 is.
Never realized it came w/ a vinyl top until I decoded the FT.
CHIP
Re: Vinyl top pros and cons? [Re: an8sec70cuda] #2131255
08/12/16 04:48 PM
08/12/16 04:48 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
the holes for the trim is where most rust starts.
Re: Vinyl top pros and cons? [Re: an8sec70cuda] #2131272
08/12/16 05:12 PM
08/12/16 05:12 PM
Kirkland, Washington
Pacnorthcuda Offline
I've had 70 'Cuda's with and without. With the way these cars are treated these days rust is NOT an issue (provided we're talking about a fresh installation).
I can appreciate both looks. To me the vinyl top 'desses-up' the car. Sorta like putting a sport jacket on.
A vinyl top also works very well with hi-impact colors (including B5 even though its not technically high impact) as it lessens the flood of color.)
One advantage that nobody has mentioned is that it makes the car MUCH easier to paint!!!----easier to maintain a wet-edge.
Also--not many cars on the road sport a vinyl top compared to years ago--its another difference in our vintage rides verses the millions of everday cars on the road.
One problem I see with the OP's car is that the gloss level of the hood might not match the vinyl gloss very well, and you will have a LOT of Black on the topside of that car.
Re: Vinyl top pros and cons? [Re: Pacnorthcuda] #2131365
08/12/16 07:23 PM
08/12/16 07:23 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Vinyl top made for a great place to set the hood when working in the engine area...
Re: Vinyl top pros and cons? [Re: an8sec70cuda] #2131381
08/12/16 07:41 PM
08/12/16 07:41 PM
pa.
dan9 Offline
dan9  Offline
pa.
I added a vinyl top to my 70 Challenger and like the look of it. You could lay the top on with no glue to see how you like it. The only con I have is make sure you get the proper glue and be patient while it off-gases.
Re: Vinyl top pros and cons? [Re: dan9] #2131438
08/12/16 08:38 PM
08/12/16 08:38 PM
Queensland,Australia
T-bar Offline
T-bar  Offline
Mine wasn't factory but the previous owner changed the colour and added the vinyl top, been on there 6+ years doesn't seem to be any rust bubbles forming in the usual spots. Plenty of older cars over here do rust but like the reply's have stated good prep work and should be right. I like my top good contrast between the colours and a quick wipe with vinyl spray and looks good too.
Re: Vinyl top pros and cons? [Re: T-bar] #2131800
08/13/16 09:29 AM
08/13/16 09:29 AM
pa.
dan9 Offline
dan9  Offline
pa.
To me some cars depending on the color look best with one. Yours looks great to me.
Re: Vinyl top pros and cons? [Re: dan9] #2131808
08/13/16 09:58 AM
08/13/16 09:58 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Looks great either way. I like your car better the way it is. What is it with all you Cuda dudes trying to make your Cuda's looking like Camaro's. Lol. Stop it...
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Vinyl top pros and cons? [Re: 6PKRTSE] #2131810
08/13/16 10:01 AM
08/13/16 10:01 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
My red Charger has a the factory vinyl top on it still. It does have some rust bubbles forming under it in places but it has taken 46 years to do so.
Re: Vinyl top pros and cons? [Re: an8sec70cuda] #2131943
08/13/16 02:13 PM
08/13/16 02:13 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
The factory did not paint the top on a vinyl top car. These cars spent many years outside as daily drivers. The rust is a long term problem.
If your collector car has been restored and kept indoors rust under the top will not be an issue.
Re: Vinyl top pros and cons? [Re: Pacnorthcuda] #2131975
08/13/16 02:50 PM
08/13/16 02:50 PM
BDW Online content
BDW  Online Content
Agree with above, I have a sublime challenger with v/top, all green would be too much for me.
Re: Vinyl top pros and cons? [Re: NANKET] #2134107
08/16/16 03:10 AM
08/16/16 03:10 AM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
^^^^ THIS.
My last 70 Gran Coupe was B5 with white top. To me, that is just about the best color combo there is for an e body. So striking. Now what you got under that hood that couldn't be covered up by a mopar scoop? devil
I’m listening.
Re: Vinyl top pros and cons? [Re: an8sec70cuda] #2134111
08/16/16 03:23 AM
08/16/16 03:23 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
One option is a vinyl wrap in the old mod top colours, I think it would look stunning but when you are sick of it you peel it off and your back how it is now. might even look at doing my 71 Barracuda.
1963 Plymouth Max Wedge
1971 Barracuda
Re: Vinyl top pros and cons? [Re: an8sec70cuda] #2134113
08/16/16 03:29 AM
08/16/16 03:29 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
1971 Barracuda
Re: Vinyl top pros and cons? [Re: NANKET] #2134115
08/16/16 03:42 AM
08/16/16 03:42 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Are you sure about that? Seems that they spread filler on the C panel seam, primed the car and put at least a cursory coat of paint over the primer.
Re: Vinyl top pros and cons? [Re: an8sec70cuda] #2134258
08/16/16 12:22 PM
08/16/16 12:22 PM
Thanks for all the comments yall, much appreciated. And thanks for the compliments on my car!
When I get around to repainting the car, the hood will be painted body color. It being black is one of those "temporarily permanent" situations, lol.
I like the idea of wrapping the roof for now just to see. I have a friend that does wraps...might be an option there.
So as far as maintenance on a vinyl top, just wipe it down w/ some vinyl spray every so often? Kinda like conditioning leather I imagine?
CHIP
