HELP!!! 70 340 A body Fan questions #2130988
08/12/16 12:08 PM
08/12/16 12:08 PM
SINY
SanityLost Offline OP
SINY
I have a question or two about the fan on my motor. Its a Factory 18" fan, 7 blade and the part number is 46237 . Does anyone know the application for said fan and IF its a direct bolt on OR a clutch type piece? Right now previous owner has a clutch mounted to it. The car in question is a 70 340 swinger auto
Re: HELP!!! 70 340 A body Fan questions [Re: SanityLost] #2130991
08/12/16 12:10 PM
08/12/16 12:10 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Jeff that's not a part #.
Ron
Re: HELP!!! 70 340 A body Fan questions [Re: SanityLost] #2130997
08/12/16 12:14 PM
08/12/16 12:14 PM
SINY
SINY
There is a Chrysler star and under that is the number 46237 I'm going to callme you
Re: HELP!!! 70 340 A body Fan questions [Re: SanityLost] #2131002
08/12/16 12:21 PM
08/12/16 12:21 PM
SINY
SINY
Re: HELP!!! 70 340 A body Fan questions [Re: SanityLost] #2131011
08/12/16 12:27 PM
08/12/16 12:27 PM
P
Paul_Fancsali Offline
P
Should have a short shaft clutch drive without the thermal spring
Re: HELP!!! 70 340 A body Fan questions [Re: SanityLost] #2131283
08/12/16 05:26 PM
08/12/16 05:26 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Five digit numbers are vendor ID numbers, the outfit that supplied the part to Chrysler.
Re: HELP!!! 70 340 A body Fan questions [Re: SanityLost] #2131443
08/12/16 08:49 PM
08/12/16 08:49 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
2863216 is the part number
46327 is the part vendor ID
The original fan would have the part number stamped in the blade. Newer replacements had an ink stamp with the part number.
Re: HELP!!! 70 340 A body Fan questions [Re: SanityLost] #2131453
08/12/16 09:01 PM
08/12/16 09:01 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
216 fans are 18.5" diameter, so it would be a 215 fan. wink
