Advice wanted front struts 07 Caravan
#2130902
08/12/16 09:11 AM
08/12/16 09:11 AM
Posts: 714 USA
Lawn Monkey
USA
My 07 caravan worn tired and true and never let me down in 242,000 miles so far needs front strut should I replace the complete units springs and shock cartridge or just the shock cartridge ?
Also if I do just the cartridge that would require a spring tool to r and r the spring??????
This van owes me nothing but I would like to keep it around a tad longer it sure is handy having a spare beater van....
Re: Advice wanted front struts 07 Caravan
[Re: Lawn Monkey]
#2130955
08/12/16 11:19 AM
08/12/16 11:19 AM
Posts: 19,453 north of coder
moparx
my advice would be to just change the complete assemblies. if you just do the shock cartridge, you need a compressor to do this safely, although if you have fab skills and know how dangerous a flying spring can be, you may be able to do this without using a proper compressor tool. but, then you have 200k+ pivot bearings, springs, and spring cushions that more than likely are not long for this life. if you figure in the other factor known as time, just opt to replace the assemblies. they are not that much more than just the shock cartridges, and if you are paying someone to do this, they are often cheaper due to the labor charge[s] involved. also, don't forget an alignment check afterward.
[Re: Lawn Monkey]
#2130962
08/12/16 11:42 AM
08/12/16 11:42 AM
Posts: 12,141 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Got time to go to a pick-a-part yard? $15 to $25 apiece complete and sometimes you can find a fairly new replacement set to boot.
Master, again and still
[Re: Lawn Monkey]
#2130986
08/12/16 12:06 PM
08/12/16 12:06 PM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
Unless you have a compressor and want to but extra parts just buy quick Struts.Rock Auto has them at a great price.Bought ones for wifes PT my brothers caravan and more.They were cheaper than I could buy them with shop discount at local parts store.easy change.Lower bolts upper 3 and IIRC the tie rods.I can do a pair on the ground in about 45 minutes and Im getting old.Rocky
Chrysler Firepower
[Re: Lawn Monkey]
#2131529
08/12/16 10:14 PM
08/12/16 10:14 PM
therocks
Niles , Ohio
Not just easy to install but most times bearin plates or springs are bad let alone the rubber parts.Just not worth the trouble.Then if you have to have someon compress the springs to change another expense.Rocky
Chrysler Firepower
[Re: Lawn Monkey]
#2131856
08/13/16 11:55 AM
08/13/16 11:55 AM
therocks
Niles , Ohio
IIRC the 07s the bolts dont adjust camber.Been a few years since i did one at the shop.The early ones it adjusted them.Now I think they just hold it tight.I think they made an adjustment setup to replace the one bolt so it could be adjusted.An alingnment is always recommened after frt end work.Just good insurance as long as the guy doing it knows something.Ive seen steering wheels be way off etc after some are done.I always tried to get mine dead straight.Rocky
Chrysler Firepower
[Re: Lawn Monkey]
#2131926
08/13/16 01:54 PM
08/13/16 01:54 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
Ive done the complete strut twice. Once had the car sitting higher. Yes higher than possibly the worn originals but higher than even when the car was new. Five years later it was still too high. The other time is was SO high my axles were not happy. There was no way these were going to settle. It was not even the same spring rate. Quite often the aftermarket will only have 1 assembly to cover ALL interchangeable models when in fact the OEM has different combinations.
[Re: Lawn Monkey]
#2131964
08/13/16 02:37 PM
08/13/16 02:37 PM
therocks
Niles , Ohio
Only had 1 or 2 that sat high and didnt settle.Some were a bit but settled in.Ive installed maybe 400 or 500 sets in the last years.Probaly 1 or 2 like I said were high and didnt settle.Most see old tired springs and shock and when new is in yeah it will be higher.Have a set on the PT nephews GMs have 2 sets His Caravan a set.All are great.We use Monroes on all installs.Had problems with other makers.Rocky
Chrysler Firepower
[Re: moparx]
#2132757
08/14/16 05:11 PM
08/14/16 05:11 PM
Posts: 714 USA
Lawn Monkey
USA
the two bolts retaining the strut to the knuckle affect the camber setting, and as one is equipped with an offset washer, and the hole is egg shaped where that bolt goes, unless you are very careful on getting the face of the rotor or strut body back to the exact position it was before, then an alignment check is necessary or you will experience abnormal tire ware and/or erratic steering/handling issues. i'm going to guess since you have asked this question, you probably do not have the tools necessary, nor the experience needed to accurately measure the original strut and get the replacement strut back to this setting. please don't take this as a slight to you. this was not my intention. just not many hobbyist mechanics have the tools or alignment experience necessary to check alignment at home. Thanks lots of experience and tools here but no I can not do a front end alignment, I order two struts 104 dollars each going to swap them out next week then send it immediately to a front end shop, looks like easy job on Youtube , I'm looking forward to the new road feel ,,,,,,, Any advice on the CV Joints, they are original with 242,000 how does one know if there worn out????? Thanks
