Page 4 of 6 1 2 3 4 5 6
Re: Tubing benders [Re: sgcuda] #2130424
08/11/16 05:11 PM
08/11/16 05:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Originally Posted By sgcuda
Mr P: Planning on putting a 12 point C/M cage on top of my frame. Will probably add a funny car cage to cert to 7.50's. By then, I hope to have the hydraulic setup.
Monte: I appreciate the concerns and inputs. Yes, I'm starting smalltime, but plan on growing as my desires and demands increase. I can't honestly say how hard or easy this is going to be. But I'm not afraid to try and I will figure it out soon enough. I've built engines in my bedroom, transmissions on the kitchen table. I backhalved my car while still on the trailer. I built the whole frame and set up the body to be bolt on with no physical help at all. You just got done saying you've built plenty of cars with a hand bender. Let me have this experience, I'm sure I will enjoy it, regardless of effort needed.
Since the main hoop is the first thing you bend
you will figure out right away if you want the
hyd unit or not... plus those are the biggest bends
(degrees) in most cars... also what radius will you
buy... MOST of my bends I used a 6" and a few 4" but
very few.... the biggest thing on bending is where the
tangent is when you start the bend.. if you screw up
a bit early in the bend you can move it... so check each
bend after you start to make sure its right... when I
was working in the exhaust lab I learned a ton bending
every day.. 35 years of that stuff(along with fuel lines)
since the lab was fuel & exhaust.... have fun with it
and take your time... also... I would rather sneak up
on a bend then over bending.. yes you can bend it back a
few degrees but it can be a PITA.. specially moly
EDIT
For a 7.50 cert. buy the SFI cert book.. I think
its $35
wave
Re: Tubing benders [Re: sgcuda] #2130645
08/11/16 10:01 PM
08/11/16 10:01 PM
Charlotte, North Carolina
sgcuda Offline OP
sgcuda  Offline OP
Mr P. Already got the SFI book. Frame is done to spec for 7.50. I've been watching several youtube videos on bending techniques, including how to determine material length in a bend and making some cheater bars for measuring out between bends. Just like anything else, practice is key. I already have an idea of how many times I am going to redo my door bars to fit right due to multiple angles on a 3D plane. I might make some test ones from pipe from Lowes, before I commit to chrome moly.
[image][/image]
Re: Tubing benders [Re: sgcuda] #2130714
08/11/16 11:15 PM
08/11/16 11:15 PM
michigan
turbo toad Offline
turbo toad  Offline
michigan
Anyone have any experience using a http://www.cagegage.com/ i think two of these would make life easier
Check out my build on Facebook Ttoad Hurley its updated regularly
Re: Tubing benders [Re: sgcuda] #2130726
08/11/16 11:26 PM
08/11/16 11:26 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
Moparts has became a joke in the last few years ...bashing beating crying ..but we all try to fly the flag..mopar has dropped the flag but yet most 40yr vets still live on ..I give you a heart felt cause if you're brand don't support you who will..I love mopar but I will never give in to the 3 times more price 2 yr wait deal..I'll fly the flag in the body but if things happen to the motor I'm done..see you in the lost lane lone..guys can't even agree on tools ..tool thread gets more hits then how to build what to build how to do what to do ..but you old guys want young guys to take over hell we can't get a answer on stuff but a thread like this all yall got something say..I'm 44 still learning and trying to enjoy..family self employed going to a divorce right now and yall more interesting then that is lol .
Re: Tubing benders [Re: sgcuda] #2130736
08/11/16 11:38 PM
08/11/16 11:38 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Toad if you take a piece of 2 foot pipe and bend it 90 it works as a reference and gives you an idea of where to start the bend. Then you just copy the bar for the other side.
Your 1st bend I like to put a mark on the die as the start point of the bend. That mark lay'd out on your 90 will give you a way to measure for the whole project. .
Re: Tubing benders [Re: turbo toad] #2130746
08/11/16 11:47 PM
08/11/16 11:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I made up something like that.. never used
that piece
wave
Re: Tubing benders [Re: sgcuda] #2130760
08/11/16 11:55 PM
08/11/16 11:55 PM
michigan
turbo toad Offline
turbo toad  Offline
michigan
Thanks FastmOp thats sound advice early in my electrical apprenticeship i bent miles of conduit and now i dont run much conduit but when I do I always seam to mess the first piece up till i get my starting point of my bends figured and take up accounted for. up
Re: Tubing benders [Re: turbo toad] #2130764
08/12/16 12:01 AM
08/12/16 12:01 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I did the same thing with the 90* bend... works
well... just make sure which end you start with...
the live end or the dead end
wave
Re: Tubing benders [Re: sgcuda] #2130769
08/12/16 12:05 AM
08/12/16 12:05 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I use a 90* bend piece all the time. The pirate4x4 site talks all about this.
69 GTX 68 Road Runner
Re: Tubing benders [Re: sgcuda] #2130772
08/12/16 12:06 AM
08/12/16 12:06 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I use a piece of 1/4" solid about 5ft long as a template for the real thing.
Mopar to the bone!!!
Re: Tubing benders [Re: sgcuda] #2130792
08/12/16 12:31 AM
08/12/16 12:31 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I have an assortment of test bends in sizes larger than 1". 90s, 45s and 30s with start of bend and length of bend marked on it and a couple inches of straight left on each side of the bend. There's always pieces of drop or mistakes around that they can made from. Helps to plan hoops and other pieces to get the fit I want. I don't think Loews or anyplace like that sell what you want to use. Pipe and tubing are two different things, both size and material wise.
Cage Gage looks like a nice tool. I've always just used a protractor. I have a variety of those in different sizes and configurations. Typically I'll pull it to within a degree or 2, check it and then just touch it up to get it exactly where I want it. Might take a couple of test fits but that's better than trying to pull a few degrees out of 1.625 4130.
Re: Tubing benders [Re: sgcuda] #2130807
08/12/16 12:54 AM
08/12/16 12:54 AM
sgcuda Offline OP
sgcuda  Offline OP
That sounds like the safest bet. I don't see myself taking some bend out of C/M. That stuff is pretty stout.
What do you guys use for hole saw blades when making notches? I tried cutting some C/M with my sawzall using DeWalt blades. Killed 3 new blades within seconds and barely touched the tubing. Ended up using a cutting wheel on my 4" grinder to cut the tubing. Normally cut to length with my chop saw, fishmouthed on my bench grinder.
[image][/image]
Re: Tubing benders [Re: sgcuda] #2130809
08/12/16 12:57 AM
08/12/16 12:57 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Small tubing benders have hash marks. When you bend tubing like I do everyday the hashes become second nature. That said it's very easy to take a die grinder with a cutoff wheel and put some hashes on your tubing bender for cages as well. All it takes is to bend a couple pieces of scrap to determine left start, right start and center, then transfer those marks to your die and mark the spots. You can buy all kinds of tools, but really all you need is a protractor and a level. When visualizing and measuring for hoop, focus on where center of tubing will be, be sure and leave yourself outside room and you will be fine. Complex bends like windshield bars look tough, but really aren't. Just use the protractor to figure the angle, roll it to that angle in die and have at it
Re: Tubing benders [Re: sgcuda] #2130829
08/12/16 01:27 AM
08/12/16 01:27 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Any decent bi-metal hole saw will work. But they won't last forever in 4130. Milwaukee, Lenox, Blu-Mol. Chinese stuff is useless. I use a variable speed 1/2 drill that maxes at 600 RPM. Speed and rate of feed is the trick, especially at angles that are not 90. If you are using too much pressure when the saw breaks through the wall of the tube, it will snag and clean the teeth off, especially when you get around to a 30 or 45 degree cut. Just let the saw cut, back off on the pressure, especially in the middle part of the cut where you're just in the thin tubing wall. A saw with 1 or 2 teeth off of it will still cut if you are using light pressure. Takes practice.
Sawzall instead of a chop saw? Milwaukee or Lenox, maybe 18 or 24 TPI. Buy several packs, they don't last forever in 4130.
Re: Tubing benders [Re: sgcuda] #2130900
08/12/16 09:00 AM
08/12/16 09:00 AM
sgcuda Offline OP
sgcuda  Offline OP
Thanks for the tips/advice. I should probably be writing all of this down in a book, but then, I would probably not be able to find the book the day I start all of this.
Monte: The angles I'm referring to is not only the downward bends but also allowing for going from the narrow roof area, to the wider area at dashboard level, then slightly narrower down at the frame. Maybe I'll just make it perpendicular from dash level to frame. I can see where a halo bar would allow for easier tube construction, now. But I like the full door bar design better.
CMcAllister: I used the Sawzall on some tubing that was already welded in place. Didn't work at all. Was using DeWalt 18T bimetal blades. Tooth the teeth off faster than I could change the blades. That's why I was asking about the holesaw. I might have attacked the tubing with too fast a rate of speed, like you mentioned. Will try some practice cuts with some 24T blades.
[image][/image]
Re: Tubing benders [Re: sgcuda] #2130943
08/12/16 11:00 AM
08/12/16 11:00 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I used Milwaukee hole saws in my notcher..
also for degrees I got this big yellow protractor
from HF... fit perfect on the center and when the
tube started to bend I would zero it then
wave
Re: Tubing benders [Re: MR_P_BODY] #2130995
08/12/16 12:13 PM
08/12/16 12:13 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
wave
That's what it looks like! !!!
Re: Tubing benders [Re: sgcuda] #2131004
08/12/16 12:23 PM
08/12/16 12:23 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
For a test pattern I use electrical conduit. Very cheap and easy to bend/test fit in the car if you have odd /complex shapes.
On symmetrical parts like a hoop, start at the center and move out.
If you are ever using seamed tubing in your bender, put the seam on the center of the inside radius.
Use one piece hole saws. Hole saws with separate mandrels wiggle and distort and will not last long.
I use hole saws in my milling machine for notching tubing. If you have that luxury, try using it. You can use the same hole saws for what seems like forever, because with solid mounting, and auto feed, the hole saws don't take a beating.
Re: Tubing benders [Re: sgcuda] #2131014
08/12/16 12:32 PM
08/12/16 12:32 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
The bends you are talking about are not tough. First you need to know how much bend you need......that's easy and then you need to see how much to roll it out. You figure the roll out by putting a protractor on a pillar and see how much it angles out. So lets say from vertical your A-pillar is laid out 10* at the bottom. You roll the tubing in the bender 10* and make next bend, not hard.
But let me save you some time on the windshield bars. Don't worry about going from main hoop all the way to floor. Go to a dash bar and make the a pillar bars two pieces
Re: Tubing benders [Re: MattW] #2131020
08/12/16 12:35 PM
08/12/16 12:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
wave
LOL... I assume you havent even assembled it yet
wave
