Re: fitting a cam into a fresh 400 block
[Re: mopar dave]
#2129589
08/10/16 04:21 PM
08/10/16 04:21 PM
Posts: 2,646 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Sometimes I take a bearing knife and cut the shiny spot off until it turns free and sometimes I just run it. I've never had a bad experience, and some of them I thought were way too tight.
2011 Drag Pak Challenger
[Re: mopar dave]
#2129639
08/10/16 05:27 PM
08/10/16 05:27 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If you know where the spot is... clearance it.. it should spin freely with just using your hand and spin a few turns
[Re: mopar dave]
#2129706
08/10/16 06:43 PM
08/10/16 06:43 PM
Posts: 25,799 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Make yourself a reamer by making diagonal hacksaw cuts in each bearing journal of an old cam.
[Re: John_Kunkel]
#2129725
08/10/16 07:15 PM
08/10/16 07:15 PM
MR_P_BODY
Make yourself a reamer by making diagonal hacksaw cuts in each bearing journal of an old cam. I have one of these sizer cams but its for a SB.. nothing for a B or RB
[Re: mopar dave]
#2129771
08/10/16 08:31 PM
08/10/16 08:31 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
It will take a while with the Scotch Brite.DAMHIK...
[Re: mopar dave]
#2129868
08/10/16 10:23 PM
08/10/16 10:23 PM
dartman366
Mt. Vernon, Ohio
because scotchbrite is an abrasive and will leave minute particles of that abrasive in the bearing surface also you will need to wash the block out again if you haven't already done so,,a bearing knife is the proper way.
[Re: mopar dave]
#2131149
08/12/16 02:56 PM
08/12/16 02:56 PM
Posts: 43,180 Bend,OR USA
Cab_Burge
I thought it had to be bent some to not rotate freely. I have heard of some people straightening them with a hammer and a dull chisel, NOT ME though You should be good, I have had to scrape more than one new cam bearing due to Mopars poor machining of the cam tunnel not getting one or more of them not the proper I.D. One of the better machine shops I use to use in SO CA would use a small cylinder hone to enlarge them
